Suspension Maxx Camm 2
Hey guys i got tired of thinking about my torsion keys being tightened so i decided to buy the suspension maxx torsion keys. The only thing i dont get is how turning the dial thats indexed with letters your supposed to match up with the numbers on the torsion key is supposed to change the amount raised... it looks to me you can turn it to what ever position and its the same, its kinda confusing cause it tells you where to set it for whatever height you want but whatever position you turn the dial it looks exactly the same.. Im planning on installing them tomorrow when im at work(Firefighter) and was just trying to get this figured out alittle more before i actually get under the truck. Any help explaining what i need to do would be greatly appreciated. Thank guys
sorry to tell you this but those torsion keys have the same effect as cranking on your stock keys.
Don't waste your time installing them, the only thing that'll change is how much of the adjuster bolt sticks out. The way the truck rides will stay exactly the same and you'll still wear components; neither of those will change because of different keys.
+ a gatrillion
then what do i need to get to level it out? I that you(Scott) have a "RC 2' Leveling kit"... whats different about that? Thanks for the info, i already got the keys, but i guess ill just sell them on ebay or something
if you want to level it out, turn your torsion key adjuster bolts... you can probably get enough height out of the stock keys to make it level.
i however recommend against this. I did it to my 2005, cranked my keys for 1.5" of increased ride height and man did the ride suck. had to go buy a 6" suspension lift to fix it :fume:
well i have the torsion keys cranked already and have had them cranked for the past year. Ive also cranked them on all my other silverados ive had in the past and havent had any problems. I just wanted to put the new keys in cause i figured they were better for my truck and might get me alittle more than what i can get now. If i was able to raise the front alittle more than what i have now then i would add a rear leaf to raise the back up as well... I already have rear leafs aswell:)
I would just crank your stock t-bar bolts to achieve about 1-1.5" of height. The new trucks (like Scotts) have a coil-over front suspension so his 2" kit is very different then what you could use for your truck.
EDIT: Just saw that you posted right before me. I think you are maxed out man. 2" body lift maybe in your future.
yeah after i asked i looked it up and realized that, i feel stupid but oh well it happens from timre to time
oh wow, you're really crankin em aren't ya? got any pics of your angles?
IF you want to get over 2-3" out of your torsion bars, look into the cognito leveling kit. The UCA will help the upper balljoint angle and keep the UCA off of the metal droop stops. It also comes with components to beef up your steering since they'll be pretty steep too. Lower balljoint and CVs will still be at bad angles, some members have shimmed their differentials to help with CV angles. And the ride will be rough.
Thats really the only way to get over 2" of crank... but seriously, id just get a 3 or 4" suspension lift before going through all that. More money up front but at least it'll be done right: parts won't wear as bad and the ride will be somewhat retained.
Yeah i might just let the idea go:/ The torsion bars arent cranked all the way, but enough to make it sit level, I already have the procomp 6 inch suspension lift
body lift time :fume:
Hell nope haha, i had a body lift on my last Z, nothing went wrong with it but not a big fan of them really. And the most i was wanting was 1 to 2 inches front and back, but when it comes down to its not that big of a deal. I got the torsion key leveling kit along with the rear leaf's as a gift, so i can turn around and sell them and be happy with the cash
Yo Matt! Didn't know you were a member over here. I need some help though, it's tough being the only torsion bar Nazi. :D
yea man, this was actually the first site i ever signed up for.... about 2 weeks after i got my 2005
Post more here, FSC sucks. :banghead:
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
