Egr Clogged Beyond Belief, Will Seafoam Unclog It?
EGR Clogged beyond belief, will seafoam unclog it?
Looks to be the original one installed back in '88, but of course no way to verify...
Anyone ever have any luck giving an egr a long bath in seafoam? Or just swap the dang thing and be done??
I usually only swap EGR's when they get stuck tight, but money being short lately, thought I'd ask...
If it is stopped up THAT bad...I would just probably replace it...but...
I might try soaking it in a pan of gas first and trying to clean it that way...if I didn't want to just replace it.
I don't know what Seafoam costs...but egr calves shouldn't be TOO expensive. If if may be the original one...it is 21 years old. It has done it's job.
If you have a can of BRAKE KLEEN...you might give it a shot of that first...see what it does.
If you try gas...remember...no sparks..no open flames..no smoking..and it is not environmentally friendly. The gas vapors evaporate into the atmosphere.
3 words......BLOCK OFF PLATE
I wish...LOL...Here in N. GA , no way that would work with the emissions being as stringent as they are..
I just went and replaced it....My Bro has his '95 TA in my driveway for me to work on, so I temporarirly stole his EGR that I had installed in there 6 months ago..
Everythings goin good now, nice smooth idle is back..
Now I need to move on and swap the steering pump to take care of that tight-turn-stall issue I have ....See my other post.....
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
