Will My Wheels Look Stupid If They Dont Stick Out?
I know a couple of you guys have been chiming in on my threads about lifting my 08 silvy extended cab.
Well.. The fabtech is here!! I am ready to put it on, but I am still deciding what to do about my wheels.
I already have 20x8.5" KMC rockstars with 305/55/20" (33x12x20) pro comp extreme A/Ts. (Almost new I had them on there last summer for a few thousand miles with just a level kit) Keep in mind I do have bolt-on look fender flares.
I REALLY want to get 22" rockstars and 35" tires, BUT as we decided in my other thread, theres literally only 1 tire available for that size. (22x35). Sooooo its got me thinking, Maybe I could just get some 35's for my 20" rockstars... I looked at some, and they sidewall isnt so bad ( I dont like alot of sidewall)
BUT the thing is, I bought these wheels thinking I wasn't going to lift the truck, so they have a near stock offset (about 5.25") so they dont really stick out much.. I think most of u guys are running like 4.5" backspace right???
SOOOOOOOOOOOO is it going to look stupid if its lifted 6" and the tires dont really stick out?? I have flares and they are prolly an inch inside the flares with the current tires on???
The difference is going to be spend $3000 vs $1300.00 just to get the wheels to stick out an inch or so.. is it worth it? I'd love to see some pics with both setups.
I suggest to use your existing 20x8.5" and see how they look to you. If all looks good then then Sweet, if not save up some up some Ben Franks or maybe you can use some of your Tax return and get a new set of Shoes...
Yippee another guy lifting his truck to be a street queen :dunno:
Stick with the 20's :seeya:
Its a $35,000 dollar truck with $6,000+dollars of modifications, for that reason... I'mnot going to be doing any rock crawling events with it... Im not made of money, if I was, I wouldnt care about beating it up.
The truck is mainly used to haul my motocross bikes around.. With that said, it does see mud. Not only at these events, but I also live on a farm, and I also do "wheel" the thing. (im sure the wheeling I do is light duty compared to what you guys consider light duty. I take it in open fields only because ill be honest with you this is my first BRAND NEW vehicle, and Im not scratching it up.
With all that said, the "mudding" that this truck does, will do the same whether its on 20" tires or 22" tires. I dont need sidewall flex, and Im not going to be doing and baja style high speed events with it, so it will be fine with the bigger wheels...
If you woulda took time to read the post, you would realize I was asking if they need to stick out so that they dont look shitty.. If so, I could always buy the 20s with a diff backspace, and still run a 35... The question is.. stick out or not?
GARB55: Its not really a matter of saving for it.. Im going to throw the 20's and 33's back on as soon as I get the lift on, but I already have the money to switch to 35's... I am just curious to see if people think they NEED to stick out or not to look right...
I guess in a few days I'll be able to post up some pix and see what people think...
edit: Man I wish I got money back from my taxes... I havent filed yet but I will probably have to pay money..
I don't think it will look bad. I would lean toward a slightly wider tire to make them look beefier. Buying a set of 22's when you already have 20's doesn't sound like the best place to spend money.
Any thoughts on spacers and aftermarket lugs?
I am running a 12" wide tire now... If I go with a 35 its going to be a 12-12.5" wide tire.. so they are fairly beefy, off road tires, not pizza cutters. Its not the best place to spend money thats for sure, pretty much any kind of investment into a vehicle just throwing your money away... I am not made of money but I will ante up the cash if the situation calls for it...
I have looked at the spacers you can get off of ebay and other places. They bolt on to your existing hub and they have new studs built into them for your wheels.
I dont know how reliable or what kind of detrimental effect they might have on the suspension and drive train. If I got them I would probably go with a 3/4" spacer (I dont think 1/2 inch would be worth it) I would be afraid to run any more of a spacer.
That would be the cheapest option to get what I want out of it.. but I dont think too many people on here would like the idea of runing them.. It would be nice to get some input from someone who has had experience with them.
http://cgi.ebay.com/ebaymotors/PAIR-WHEELS...sQ5fAccessories
Something like that.. They are aluminum so they cant add too much weight to the setup, plus its a centralized weight.... other question is will they work with aftermarket lug nuts.. cuz those ones on it wont work with my wheels, I have to run spline drive lugs
haha told ya they dont go over well around here.... Its probably for good reason, I duno
It's the fact they put a lot of unneccesary stress on the lugs/hubs which could lead to failure.
If you do decide to go with spacers, make sure you get ones with their own lugs.
My Bad, I wish I had had plenty of Ben's then I would not have to ask I would just do what I would like. As stated before see how it looks with what you have, if you like it stick with it if not get a new set up! Hard to tell with out some photos. Post up some photos and you get plenty of feed back. Best of luck on what ever you decide.
The only reason I mention the spacers is the fact that I just helped one of my subs put 22.5" rims on his F-350 Dually. The spacers were incredibly stout, probably stronger than the wheels themselves.
No kidding.. were they aluminum?? If I bought them I think I would definately want the aluminum simply because of the weight savings over steel.
I am gonna talk to my boy w/ the fab shop (helpin me out on the install). I am gonna show him some pics of those spacers with the lugs like in my link above and see what he says.
The more I think about it leaving the 20's would free me up the money for some shorter other things I that may be a waste. I gotta decide: 2" bigger rim vs Gearing, and a 1.5" body lift.
I know when I first thought of the idea of a spacer, I didnt realize they made a spacer like the one I posted. Being aluminum its not very heavy..and I am failing to see how much its going to strain it, if I go with a 3/4" or 1" spacer maximum. Its still going to focus about the same amount of stress as a wheel with an inch less backspacing, like alot of these guys are running.
As I said, the truck doesnt get abuse, I dont spin tires, I never go off-road at a high speed, I even take turns slow because they wear these expensive tires out... I am actually in the market for an previous body style 1500 or F-150 to use as a beater truck.. Once its lifted it is going to just be used for loading bikes and on sundays kinda thing.
Makes me think I might be able to get away with those spacers for an extended period of time without problems
It will look fine. The lift is going to increase your track width by a couple of inches up front, thus pushing the tires outward. I am running an 8.5" wheel with 5.5" backspacing and when it rains my truck looks like it has been offroading because the damn tires stick out.
I think it will look bad.... You should get new 20s and 35s......
......And sell me your current set =D
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
