Tools Explained By A Do-it-yourselfer
Silverado4x4
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the
chest and flings your beer across the room, denting the freshly-
painted vertical stabilizer which you had carefully set in the corner
where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under
the workbench at the speed of light. Also removes fingerprints and
hard-earned calluses from fingers in about the time it takes you
to say, 'Oh poopoo'
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their
holes until you die of old age.
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor
touch-up jobs into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked,
unpredictable motion, and the more you attempt to
influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt
heads. If nothing else is available, they can also be used
to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable
objects in your shop on fire. Also handy for igniting the
grease inside the wheel hub out of which you want
to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood
projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you
have installed your new brake shoes, trapping the jack
handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily usedby most shops to
cut good aluminum sheet into smaller pieces that more easily
fit into the trash can after you cut on the inside of the line
instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength
of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids
or for opening old-style paper-and-tin oil cans and
splashing oil on your shirt; but can also be used,
as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to
convert common slotted screws into non-removable screws.
PRY BAR:
A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50-cent
part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is
used as a kind of divining rod to locate the most expensive
parts adjacent the object we are trying to hit.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard
cartons delivered to your front door; works particularly
well on contents such as leather seats, vinyl records, liquids in
plastic bottles, collector magazines, refund checks, and
rubber or plastic parts. Especially useful for slicing work
clothes, but only while in use.
DAMMIT TOOL:
Any handy tool that you grab and throw across the garage
while yelling 'DAMMIT' at the top of your lungs. It is also,
most often, the next tool that you will need.
wow that seems to be my way of using those tools sometimes, but it needs to have one about loosing tools out of the tool belt while up a ladder or up a electric pole lol.
Found the thread from December...with a few added
Edit: gimme a few,I'll get it........shit
Tools 101
I guess the CR's kickin' in
    RyGuy43
    RyGuy43
  • Who's Online   4 Members, 0 Anonymous, 575 Guests (See full list)
