Auxiliary Roof Mounted Lamp Switch
I have been trying to think of something to use this switch for. I was thinking either roof markers or fog lights of some sort. The only thing I was worried about was over loading the circut. Anyone have any ideas as to what I can run off this switch without starting a fire or melting the wires? If someone has any better ideas than roof markers or fog lights I would like to hear them aswell. Thanks.
Put a CB, Fog Lights, Marker Lamps, Wilson Repeater, or anything you want. I would use this as the signal wire instead of the power wire to whatever you connect.
You could use it for some bed lights like the ones that I installed possibly. http://www.gm-trucks.com/forums/index.php?showtopic=93508
I may use mine for auxilary reverse lights / bed lights mounted on a headache rack (backrack, etc). Please post if you figure out how to use the switch as a signal for a relay--guessing it's labeled in one of the fuse boxes.
Found you a good link that describes how to use a switch to signal the relay. Too hard to explain in words...
http://www.offroaders.com/info/tech-corner...tive-wiring.htm
The VYU plow prep. beacon switch runs on its own switch/power line/ fuse
(stud 1 IIRC) and relay. The relay is located in the upper left rear B pillar
in the gmt-800/900s. The wires are deadheaded above the headliner on
the left side above the driver (gmt-800) or in the center front overhead
interior light area in the gmt-900.
For full info. and pics go here:
http://www.letstalksnow.com/forums/showthread.php?t=9623
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
