Tires Tires Tires
on day #4 of '01 Denali ownership, and I need 2 new tires (and alignment) - not unexpected for an older used truck.
stock tire size is 265/70R17
what's everyone's preference for daily driving (no offroad - um it's a Denali XL)?
Toyo Proxes? BFG? Goodyear? etc?
Michelin LTX m/s
Considering I like a little more aggressive tire, even if it's for street, I'd look at the Cooper Zeon's
:P +stupid
:crackup:
Michelin LTX m/s
+1 Great, long lasting tires. I put them on my truck within a week of buying it. My parents trucks/suvs have always ended up with these tires. They aren't cheap, but great riding and last forever. People on tire rack have claimed to get over 100k on them, my parents had 60k on them when they traded in their Yukon and they still looked really good.
:P +stupid
:crackup:
:crackup:
You're in Folsom, Cali.....any big threat of snow.........Michelin LTX for pounding pavement
snow is just a 1 hour drive from here :P (and heck, the ocean is only 2 hours!)
I just got 4 of these BIG O BIG FOOT A/T ALL TERRAIN
265/70R17/SL 115 S OWL
Warranty: Big O 3 Year / 50,000 Mile
Treadwear:500
Traction: A
Temperature: B
all 4 out the door, $790 installed (including a 4-wheel alignment, and they rotated/balanced my tires on my Mazda6 too!)
on your denali, those 17" are a weird size so to say, most tires are passenger/ suv rated. The cooper zeons wont offer i size like that i think there geared towards people who have 20's or bigger.....i belive for the denali name and look some of those tires will be to aggressive of a look for that truck, that being said if you go with a contiental contitrac or the typical michelin like you see on the new benz's youll have a great ride but may sacrafice off road abillity...as in snow if you get that. The best i can seem to find in that size seem to be the perreli scorpion atr''s and or the goodyear triple treads. check it out on tire rack.
Treadwear:500
Traction: A
Temperature: B
Congrats on the purchase, keep us posted on your experience with them.
BTW, that's about what I paid for my BFG A/T E's.
I didn't know Oprah had a tire brand.....lol!
LOL - that's a good one! They're a tire chain, not everywhere - but they did me a good deal since they threw in the alignment plus these tires are fully covered for 'anything' sidewall, nails, bad wear, etc... I used them a few years ago, and have been pretty happy with them.
    • Diesel or gas?  The 37s will obviously, drastically reduce mpg, but the gasser will take a bigger hit to mpg, and power.    I wouldn't sweat a gear change on a duramax at all, and unlikely on the gasser either. You're obviously not concerned with acceleration or towing, and the 10spd will find itself in the right gear without much hunting, if any.
    • I understand. It is disturbing to think a manufacture asks so much and gives so little in engineering support. This is not a GM issues, this is a greed issue and one the ALL practice.    My intent was not to remove the wind from anyone's sail but rather to point out the areas deficient so that they can be discussed with improvements the goal. But to do that you have to know the truth and what that truth is.    The commercial interest are honed in on a few select issues in which they control all the variables and are not forthcoming in the least with their customers about the details. Failure is the only thing that drives these people to improvement. One way not to fail it to manage public "expectations". The set a bar they can clear and put their thumbs under the suspenders with chest puffed.... Only the internal data tells the story fully. As we don't have access to that for decades then we have to generate it ourselves. UOA's with data that matters.
    • I had skimmed through that article when you posted the link and honestly I felt rather defeated in a sense and realized that all these years in changing oil that in fact putting in what I was told was a good quality oil was probably not filtered as well as it should be although the filter put on the engine would be what ( as long as it never went into bypass mode ) would be the final filtering of the new oil that the engine components would first see, but then the filtering media itself is not up to par to what is ideal because a full flow filter would be too restrictive to filter fine enough for the engines best outcome in the long run. Only one of our tractors over the years which was a Versatile with a 855 Cummins had a separate bypass filter, some engine manufacturers did spec a partial bypass system within the main oil filter but I don't believe any other trucks or equipment I was servicing used such a filter. No doubt a product like the Amsoil bypass system is of benefit as long as nothing goes sideways with the extra plumbing and filter such as a rupture/leak that could cause the oil to pump out of the engine ( yes that Versatile had a remote canister with hoses routed to it as well ). With the idiot egr system on a diesel and as a result forcing a lot more soot into the oil, that certainly isn't helping the diesel engines cause or as you pointed out the GDI engine issue with creating more soot and aside from having a fancy secondary filtering system, changing the oil more often helping lower the total soot load.     So oil manufacturing and the end product is not something one can control and I wonder if there are specs on what various oil packaging companies produce in particle count or size. As to the filtering, if the OEM is not designing a filter size and spec that is really what it could be, they too are short changing the end user and so what is the answer. Of course as you say the oil side can only do so much if the air side isn't keeping up its end of the picture and air filters are only so efficient and if in a dusty environment such as farm or construction or driving gravel roads there is a lot of dirt to filter out and some of that ends up into the air stream.    Of course the irony in places like where I am where they dump the salt on the highways but also will mix in some calcium or outright pure calcium for problem road area's, or using calcium as dust control on gravel roads, the vehicle that gets used in that environment may rust out before a properly engineered engine and maintenance finally wears out so one has to face that reality in the rust belt.
    • Has anyone run these on their 2500?
    • have you stuck with dealer oil changes since then? I made the same switch after getting tired of crawling around under the truck, but I’ve found some dealers are way better than others about getting you in quickly. Curious if yours has been good about scheduling or if you’ve had to look elsewhere for quicker turnaround.
