Check Engine Light- Questions
Hi all,
Just got an '06 Savana with the 4.3L.
Today MIL comes on. Is there any way to check codes on these with out a scan tool? On my Chrysler you can turn ignition on-off 5 times quick to get some codes.
If not, I'll be buying a scan tool tomorrow. Where will I find the OBD port? I haven't looked, but I presume it will be under the drivers side dash?
TIA,
Brad
Under drivers side dash is correct. You can't miss it
Bought a nice scan tool, plug it in according to instructions and the scan tool will not start up. Could there be a fuse out? I know the cigarette lighter does not work.
Are the fuses under the hood?
Some are under the hood. Others are inside. My cig. fuse is under the hood. Fix the no power to lighter problem that should clear things up. Also make sure your scanner is plugged in good.
Damn, I wish I got an owners manual with this van.
Oh, this forum is a great resource. Thanks,
Brad
Got my fuse located(under the hood...holy cow tight squeeze there), replaced it and got my scanner hooked up. Got code P0128 which indicates a possible faulty thermostat. Makes sense too since the temp gauge always reads at around 70* after some time.
Does this sound likely?
Brad
Are we talking celsius? If so that's only about 158F. Way too low. Sounds like you've got a stuck thermostat.
I don't think the gauge specifies *F or * C. The gauge ranges from a low of 40* to a hi of 160* with 100* right in the middle of the operating range.
Ya, sounds like a thermostat, huh?
Got to be Celsius. 100c is 212f. Duh! I see you're from Ontario. :thumbs: Are you getting heat from the heater core? Does it take longer now to get heat compared to when you got the truck?
My mistake...it does *C on the gauge, and it goes from 40-125 with 100 in the middle. It never goes above 70*. I just got the van last week. What is proper operating temp?
Around 190 F.
Got to be Celsius. 100c is 212f. Duh! I see you're from Ontario. :lol: Are you getting heat from the heater core? Does it take longer now to get heat compared to when you got the truck?
It shows a 195 F. stat. That would translate to like 90 C.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
