92 Suburban Wont Idle
bsiev
I have a 1992 Suburban that until last week, I used to drive everyday. I shut it off one day and a few hours later started it back up to leave. Now for some reason it has developed a bad miss and will not idle without help, in or out of gear. it also acts like it is starving for fuel when you try to rev the engine. The other day I went over to work on it and found that if you turn the steering wheel back and forth it will find a spot and run fine, the second you trun the wheel again it goes right back to not idleing. In all my years I have never seen or heard of steering affecting the performance of the engine. Any Ideas. Thank You very much
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
