Quality Of Ready Lift
would you guys recomend it. i can get the 2.5 leveling kit and the block for 275. need the block so i can tow my race trailer and not be ass low. was thinking the 285/70/17 mickey thompsons would be the biggest i can fit on there with stock wheels. if you think any other would be better and why please let me know. i have searched and searched and still can't find the answers i'm looking for
The ReadyLift is a fine kit. Most people on the site go with the Rough Country kit its alot cheaper. They are different designs. It all just depends on what you want. The price you mention includes the rear blocks for the 2.5 Ready Lift?
I did the Ready-Lift on my truck and I like it. I did just the front though. In the rear instead of adding blocks and putting the "rake" back into the truck I ordered some air bags. that way I can custom tailor the rear to what I have in it or what I am towing. I havent installed the bags I just ordered them over the weekend. I had a set of them on my other truck and really liked them. I tow a open race car trailer with box and tire rack on the front. I hooked it all up to see what it looked like and it wasnt pretty. It would probably sit about 1 inch dropped in the rear or so if the truck was stock but leveled it looked like it would not tow well. The bags will fix this.
Good Luck with whatever kit you choose.
I don't think there is anything wrong with ReadyLift....I was originally looking at getting the ReadyLift for my truck. However, I quickly learned (at the time that I was looking) that they only offered a 1.5" level kit which meant that I wouldn't be able to put 285 tires. Towards the middle of last year they came out with the 2.25" leveling kit (66-3085), and they also started offering the 3" OEM style blocks (66-3003) for the rear.
I ended up going with a DayStar 2" kit which is made out of a harden polyurethane material instead of aluminum. From what I've seen, not to many people on this site have the DayStar, but it is very common in my area and so far I like it. I do think that it raised the front of my truck a bit more than 2" because my front end appeared to be siting higher than the rear. So I ended up taking out the factory 1" block and put in a 2" block.
If I had to do it all over again (especially with the new ReadyLift kit) I'm not sure which one I'd pick. I do agree with the concept behind the DayStar kit, and also I have heard concerns about the aluminum corroding.....but I don't think its really a big concern. It all depends on what you want to pay and personal preference. The DayStar kit cost me about $132 plus the cost of install and allignment.
Here is the link to the DayStar site just incase you are curious
DayStar
what bags did you order and what does it take to install them, price and ride quality changes. the droop is what i don't want to see and where does the airbag stuff go aka pumps and tank
Airbag installs are pretty easy. Most consist of mounting a bracket to your frame, a plate on your leaf, then the bag goes between the frame mount and your leaf spring. Then run the air hoses where you want them. Price is about 200-300 range, with compressor about 400-550. The ride will stiffen up of course, but only with air in the bags. When you don't need them, simply deflate to about 5lbs and ride will be the same as stock. You don't need the pumps, unless you are towing a lot and want to be able to in/deflate while in the cab of your truck. Otherwise you can just route the air hoses to the back of your truck, where you can use any air pump to inflate them.
I have the ReadyLift on, and i've had no issues at all...good product, but I haven't used anything else so I can't compare.
One thing I noticed was even after my 2.25 ready lift, my truck still had that "rake" that people talk about without having blocks put in. So you never know, you may not need them.
The Ready Lift 1.5" kit is a top spacer, the 2.25" kit is the 1.5" kit plus a Rough Country style lower strut block. I had planned on getting the Ready Lift 2.25" but looked at the Rough Country and was sold on it because it's cheaper. Mine seems to sit level, I do have a toolbox in the bed which may help make it level since udeleon mentioned his was still raked with the 2.25" kit.
i put the ready lift 2.25 on my truck at about 4000 miles it did sit a little higher in the front than the rear but now the suspension has sagged a bit so it sits even for the most part
I'm on day 4 or 5 with the Ready Lift... Several people have said the back appears to sag, and I even thought going down the raod today that I felt as if the back was squating. However I did not notice and loss of steering which would indicate really bad squating... I'm conisdering adding the blocks... Acctually all ready talked BIL to help me install at his shop when I buy them later in the week...
i added this kit to my 08 last week along with 28/65/r18 BFG's and at this point have no complaints. truck looks level to me and i'm no longer bothered by the nose down look it had before. i'd recommend it.
Full week tomorrow on the ready lift...No problems. Love the look of the truck.
Ride is 100% smoother than before.. Some of this is due to the Cooper zeon LTZ's. I think that a lot of the ride is due to the better balance of weight.
Still pondering on the 1 inch adder for the back... Sometimes I look at the truck and it looks right, others, it looks low in the back. I did take some measurements...Front ground to top of wheel well. 40 5/8". Rear ground to top of wheel well 40 1/2". So I guess it really is Lower in the back.
Went off road on Easter Sunday. It was raining here, and had to make a trip out to the farm. First time ever I wasn't worried about getting stuck in the wet grass... Truck got a couple of specks of mud on it and the oval steps are covered... think I may need mud flaps...hello chrome ladies.... not.. :thumbs:
my fiance got them for me as a wedding gift. hopefully they'll be here when i get back from jamaica (wedding/ honeymoon). then i just have to save up for the 285/70/17 mickey thompsons
got the set in, now i'm going to make a copy of the front pieces and resell the ones i got. if anyones interested let me know. also if anyone would like me to make them a set let me know and i'll do it when i make mine
  • 1 year later...
I know this is an ancient thread but what size tires are you running on this? Your truck looks real nice. Looks like you have MT-Rs on it.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
