Help
firemanrj
I have an 1992 Fullsize 4x4 Blazer. The Vin is 1gnek18k7nj359513, can anyone tell what the ratio of the rear end is. Thanks.
jack the rear up and rotate the tire. mark the drive shaft and count how many times it spins each time you spin the tire once..
3 full turns and a little- 3.23
3 full turns and a half- 3.42/ 3.55??
3 full turns and 3/4- 3.73
ETC ETC
Or you can open your glove box and check the RPO codes.
I think these are correct:
GU1 for 2:41 ratio
GU2 for 2:73 ratio
GU4 for 3:08 ratio
GU5 for 3:23 ratio
GU6 for 3:42 ratio
GT4 for 3:73 ratio
GT5 for 4:10 ratio
HTH
Joe
ETC ETC
