2003 Suburban With Steering Wander
I have a 03 Suburban LT 4x4 with the 5.3 engine. The truck has 99,500 miles on it, and runs and drives great. The problem is that I am having a hard time getting rid of a wander in the Steering. I am hoping you guys can help me.
Here is what I have done so far, my steering gear box was bad so this was replaced with a rebuilt one, as thats all you can get. The Idler arm and Pitman arms were also both replaced.
The Tierods, Ball Joints and all other Susepension was checked out by an ASE mechanic, and said to be good. He is also the one that installed the Steering box for me.
I then had the Alignment redone and it is in spec now, the Toe and camber were out after the suspension work. The tires were Rotated front to back to make sure the tires were not causing any problems. My shocks are Aftermarket Bilstein's and only have about 30k on them. They are good also.
What happens is when driving down the highway and the road is bumpy, the car will want to wander some, its not near as bad as it was now that the stearing gear was replaced. Before that you could hardly keep the car in your own lane. What I do notice is that it almost at times feels as if the car is wobbling from the Passenger side front to the driver side back. Not sure how to explain this feeling but almost as if it is floating on that front side at times. what I am wondering is what could cause this?
How do you know if you have a bad Wheel Bearing or Hub? I am wondering if maybe this is the feeling I am getting. I do not have any noises from the front end of the car at all though, it is all tight and good, except whatever is causing this problem. The sway bar is ther eand the links are also good.
Thanks for any help you can give.
Bryan
Bryan
I had some of that "wandering" going on when my intermediate shaft was toast, but more of a looseness in the steerring wheel. Also you may want to have the allignment checked, if you haven't. I had one shop tell me it was alligned dead on the nuts even though the truck pulled to the right. Had someone else look at it and it turned out it was off by a good amount.
I had the Alignment done on Tuesday night and it is good, by the print out of all the angles. It does not pull at all, and will now drive straight down the road.
The Intermediate Steering shaft had the clunking noise when I got the truck, and it was replaced by the dealer for this. So this part is only about 1.5 yrs old, but the wander is actually in the tires more so than the steering wheel.
It is much better than it was before. But still not perfect.
The Rear Suspension was not checked, but it does have Bilstein shocks back there also that were new 30k ago. I also have the Airlift 100 Bags in my rear coils, I checked both Pressures on these and actually added some air to both to see if it would help any, but still no different.
It almost feels l ike the passenger side front wheel, slips towards the outside of the car at times while drivign, to make this hovering feeling. Thats why I was wondering if the bearings in the wheel would do this.
There did not seem to be any play in the Hub, when the tires were off, but I have read on here it looks like some may have had the same problem and this caused it.
Bryan
USUALLY, but not always, you will hear a humming sound coming from the hub if the bearings are bad. This happened on 3 different cars that my brothers have owned. The humming would increase and get louder the faster you drove. Also, if you have anywhere near you where you can take turns at a pretty quick speed like 30mph or so (like the interstate on ramp or off ramp) that will help you diagnose it. My brothers car would hum real bad but it stopped when he was going into a left hand turn and most of the weight shifted to the right of the car. Turned out that the left hub was bad. Same thing happened on another brothers truck about a year later.
I would also have all the tie rods and end links double checked.
sounds like somebody cranked up your torsion bars...that's where I'd look next...I'd seriously invest some time into actual ride height...
Your hub bearings are ok
  • 4 weeks later...
What about the tires themselves? Is it possible that they are bad? If you were having a pulling problem for a while, then replaced some of your parts, it may be that the tires are bad. I know that you said that you had them rotate the tires (front to rear) to check it out, but......you never know. I would like to know what the problem is when you find out.
Seems simple enough, but check air pressure in tires/tread depth and air bags in rear. I was driving a big truck from VA to SC, same symptons that you are complaining of, at first fill up dropped pressure in tires, and rode like a dream after that, no more fighting.
There is a possibility that you have a broke belt in one or more tires.
From your description...probably right front.
Broke belts can cause all kinds of weird driving sensations.
If your spare is good, and the same type tire...try putting it on one wheel at a time.
Or if you know someone that you can borrow a KNOWN GOOD wheel and tire that are like yours, put it on, and switch it around till you find which one of yours is bad.
Sup,
The bearing can absolutely do this... Check the front tires for a tapered tread pattern on the tire that the truck is pulling towards. Also, pull up somewhere drive straight and stop. Then get out and look how straight up the tire stands from side to side. Past that... You said they aligned the truck.... Check how tight they tighten the control arm bolts... If they have the top loose the truck will pitch and run in an odd direction. GMT trucks are pretty quite from the factory... A good many of these front wheel bearings I have changed people said that the tires needed rotating or something (i.e. the tires had an odd tread wear)... Also, if its the bearing find a new alignment shop... B/c they suck.... The truck could not have been aligned if the bearing was bad... It would have gave a different reading each time...... (i.e. they did not check it twice)
JBo
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
