Allblkdout07 Short/quick Video Compilation
First time trying to take and post videos. Friend took a few earlier this evening with his small 7.2 Megapixel camera, quality sucks, oh well.
Truck actually sounds alright, I had been complaining how it sounded weird since the AEM was added a week after my EFI Live tune. I guess it sounds ok. :lol:
I also was in my neighborhood so I really drove quite moderately, I really just wanted some slow rolling vids. In the second clip it looks like kids were running away from the truck..lol
WTF? I can see your headlights. :lol:
:lol:
Not only that I saw daylight UNDER the truck. I thought that truck was so stealthy that id blocked out light?
:lol:
Looks really good Umberto. :lol:
Thank you. Not that many comments though...hmm. Next time I'll take and post HD moveis :lol:
Anything that involves clicking a link to an outside site isn't going to get a lot of feedback. :lol:
Truck looks great though, I can't wait until I get a chance to shoot it (hint hint... :lol:).
If I were a kid on that block, I'd run into the house and hide under the bed too... :lol:
:lol:
Thanks guys, yeah how do I imbed the movie from photobucket? It's not possible I'm assuming.
Yeah Dan, shoot it all you want, please get some decent pics for me.
