Service Airbag Is Killing Me !$#!%%^!%!%
rcooper73
I understand this has been discussed before, but I could use a more detailed answer. In my 05 Yukon XL, the "Service Airbag" message has come and gone a few times. I took it in to a dealer and the response was that the error was "from an internal source and the assembly will need to be replaced". Close to $900. From what I have read on this forum, there are a number of places throughout the vehicle that could cause this error message. Is there a specific code that locates a specific spot that is causing the problem for this message to display?
Thanks for any help offered!
New guy.
I've read of some airbag controllers which retain the error codes from intermittent problems. And others do not.
Were they able to check with a scanner and find the code? Or was this not possible with your system because it does not retain the codes in memory?
If they did not scan it, ask if your vehicle retains these codes or not.
I'm not 100% certain about your model but I believe the codes are the same for all GM vehicles. Here are the codes I've found.
B0040 - Left Front/Driver Side Deployment Loop Resistance Low
B0041 - Left Front/Driver Side Deployment Loop Open
B0042 - Left Front/Driver Frontal Deployment Loop Circuit
B0043 - Left Front/Driver Frontal Deployment Loop Circuit
B0044 - Left Front/Driver Frontal Deployment Loop Circuit
B0045 - Left Front Side Deploy Loop Short to Ground/Voltage Out of Range
B0051 - Deployment Commanded
B0053 - Deployment Commanded with Loop Malfunctions Present
B0057 - Right Front/Passenger Pretensioner Deployment Loop Resistance Low
B0058 - Right Front/Passenger Pretensioner Deployment Loop Open
B0059 - Right Front/Passenger Pretensioner Deployment Loop Short to
B0061 - Roof Rail Module-Left Deployment Loop Circuit
B0062 - Roof Rail Module-Left Deployment Loop Circuit
B0064 - Left Front/Driver Pretensioner Deployment Loop Resistance Low
B0065 - Left Front/Driver Pretensioner Deployment Loop Open
B0066 - Left Front/Driver Pretensioner Deployment Loop Short to Ground/Voltage
Out of Range
B0068 - Roof Rail Module-Left Deployment Loop Circuit
B0069 - Roof Rail Module-Right Deployment Loop Circuit
B0070 - Roof Rail Module-Right Deployment Loop Circuit
B0071 - Roof Rail Module-Right Deployment Loop Circuit
B0073 - Supplemental Deployment Loop #1 Resistance Low
B0074 - Supplemental Deployment Loop #1 Open
B0075 - Supplemental Deployment Loop #1 Short to Ground/Voltage Out of
Range
B0077 - Left Front/Driver Side Impact Sensor (SIS) Malfunction
B0078 - Right Front/Passenger SIS Malfunction
B0079 - Incorrect Left Front/Driver SIS Installed
B0080 - Discard Left Front/Driver SIS
B0081 - Incorrect Right Front/Passenger SIS Installed
B0082 - Discard Right Front/Passenger SIS
B0086 - Supplemental Deployment Loop #2 Resistance Low
B0087 - Supplemental Deployment Loop #2 Open
B0088 - Supplemental Deployment Loop #2 Short to Ground/Voltage Out of
Range
B0090 - Active switch voltage out of range
B0091 - Active switch: wrong state
B0092 - PPS passenger detection error
B0093 - PPS/CPS self-test malfunction
B0094 - CPS childseat detection error
B0095 - SDM-PPS/CPS mismatch malfunction
B0100 - Electronic Front End Sensor 1 Performance
B0101 - Electronic Front End Sensor 1 Performance
B0102 - Electronic Front End Sensor 1 Performance
B0103 - Electronic Frontal Sensor Circuit
B0104 - Electronic Frontal Sensor Circuit
B0105 - Electronic Frontal Sensor Circuit
B0109 - Side impact module-Left Rear deployment loop resistance is less than 1.3
ohms
B0110 - Side impact module-Left Rear high circuit is less than 2.4 volts
B0111 - Side impact module-Left Rear high and/or low circuits is short to ground
or short to voltage
B0112 - Side impact module-Right Rear deployment loop resistance is less than
1.3 ohms
B0113 - Side impact module-Right Rear high circuit is less than 2.4 volts
B0114 - Side impact module-Right Rear high and/or low circuits is short to ground
or short to voltage
Out of Range
Range
Range
ohms
or short to voltage
1.3 ohms
or short to voltage
This is very helpful and I appreciate it. Now I can have a discussion with the service manager that I feel was extremely vague about the reason for the error message.
