How Long Was The White Diamond Package Available?
When I was shopping for a new GM truck. I knew what I wanted, but i had absolutely no idea about the White Diamond Package as it was no longer available when I started shopping. After seeing the paint, and realizing that it is a rare color for a Silverado and is discontinued, that sold me.
I was wondering, how "rare" or "unique" is my truck, if anything... I really don't care that much, I was just wondering as everyone I talk to or see always tells me they have either never seen one or have only seen one other.
*** Sorry for rocking the new threads this evening, I had a long day and was just thinking about stuff that I have been wanting to know or that's been bothering me for awhile ***
I don't know how rare they are, but since I've seen the first one... I've seen several now...
Isn't it a color option listed on the GM's website now?
I'm sure it's an option on GM's website, considering it's a Cadillac color, but unless it lists specific models and their associated color options and the diamond is included in said color options...then I don't think it would be offered anymore.
Sorry for the odd english...ive been writing papers all day
odd, when I first saw the truck, I searched the web and found it was offered on the GM website, but now... its not. :throwup: I just went and looked. It was offered as "white diamond package"
It is not discontinued, they just renamed it to the "Sperm Edition"
:dunno:
I don't care who you are, that right there is funny :puke::throwup:
:throwup:
I hate all of you. :dunno:
It's not SPERM colored at all...but thanks to my crappy iPhone pics and every other Diamond owner's mediocre camera work, the pictures turn out all manjaculate-like. FML
I just looked, its still availible on the GM website under "build your own"
I had to choose crew cab LTZ but it was listed.
ADDITIONAL EQUIPMENT
White Diamond Edition, (Limited Availability) Includes White Diamond Tricoat exterior color, high-performance suspension package, 20" chrome-clad aluminum wheels, P275/55R20 touring, blackwall tires, chrome recovery hooks, highly polished exhaust tips, chrome mirror caps and door handles (except tailgate). $1,995
I've been seing several on the lots around here lately.
Maybe that's why they're going broke, all that diamond dust there using in that paint! :throwup:
I could have happily went the rest of my life without ever seeing that word.
:throwup:
There are quite a few around my area as well (as a matter of fact the dealers seem to think it's the "next big thing" and have 2 or 3 in stock at each dealership).
One warning -- I talked to a few friends who are all involved with different body shops. They all said that the color is IMPOSSIBLE to match if you have to do any bodywork later on because of the pearlescence of the paint.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
