Ok So I Pulled My Fram Air Filter
After reading all the negative posts about Fram, I pulled my Fram air filter I installed a few months ago. I had no idea Fram was that bad, I learn a lot here reading the post and I appreciate all the help I get when I ask a question. Picked up a Puralator Pure Air Microninic air filter, supposedly has some oil coating. Any thoughts on this filter? Thanks in advance, Jake.
I kinda figured that Mikey, but I thought just change it anyway. The real killer is my mechanic uses Fram oil filters and that is what's on my truck now. I don't want to ask for a different kind I have been going to him for over 20 years and one of the nicest people I know, kept my wife’s shtboxes running while we saved for our first house.
So spend $4 at the parts store and hand him the filter you want him to install. Why would he care, he gets to charge the same price for an oil change and he uses less product.
I kinda figured that Mikey, but I thought just change it anyway. The real killer is my mechanic uses Fram oil filters and that is what's on my truck now. I don't want to ask for a different kind I have been going to him for over 20 years and one of the nicest people I know, kept my wife's shtboxes running while we saved for our first house.
You could always bring in your own filter when you get your oil changed. What kind of oil does your mechanic use? Just like Fram oil filters there are certain oils I would stay away from as well, Quaker State being one to avoid. Changing the oil and filter on my 2006 GMC extended cab 4x4 w/ the 5.3L V8 is the easiest of all the vehicles I've owned. I don't have to jack up the truck, so I just slide in from the drivers side and I can reach the drain plug and filter easily. In fact the drain plug and filter are located so close to each other I can take them both off pretty much at the same time and the oil catch pan can catches everything w/o having to move it. You may trust your mechanic, but I'm leery of many shops actually doing the service you asked for or using the oil that you requested/paid for. For convenience sake I tend to use a Firestone shop that is close to where I work, so I would usually drop off the vehicle in the morning and walk to work and then return after work to pick it up. I've asked for Full-synthetic oil and when I picked it up the window sticker had the Synthetic-Blend checked, so I called them on it and he said they used the full synthetic, but accidentally checked the wrong box on the sticker. I've been even more leery since I saw this TV documentary where they used camera's to spy on automotive repair shops and you could see the shop never did the service they said they did. It's easy to see when you have tires changed that they did what you asked for, but if you get a fuel system or tranny flush you really never know for sure. Many of these shops take no pride in their work as well and when you look over the job they did I've found broken brackets, scratched wheel covers, grease on things that should not have grease on them, so I've lost confidence in the so-called "Professional-Job". Most shops just want to get the vehicles in and out as fast as they can and they tend to cut corners and other shops want to fix things that are not broken and then over charge you for the inferior parts they used. Sorry about my rant, apparently I have some bad experiences in the past and I just needed to vent. :)
i just ordered a case of Napa gold filter off ebay for $39 shipped. Just bring one with you every time you head to the shop.
I've personally never heard or seen anything bad about the Fram air filters. It's their OIL filters that are pure junk.
I bought a Fram air filter once about 10 years ago to replace an OEM filter (for wife's car). It had about 1/2 as many pleats as the OEM one had.
Fram = Crap!
Change the filter once a year and don't bother with that filter detector thingie attached to the air filter box, it does not work. As for type of air filter, you probably would have been ok keeping the Fram in. Its the Fram oil filters which I won't buy.
Okay, me being a person who always seems to fall prey to "theoreticals", I went ahead and trusted the air filter change indicator. When I hit 97,000 miles and it hadn't moved a damn bit I decided to see what the heck was going on in there. Well, a dirty air cleaner is what was going on in there, couldn't get ANY light through it. So, that restriction indicator thing is officially a P.O.S. Every 30k for me now.
What I find odd is that, if I'm reading correctly, your mechanic has been using Fram filters in your vehicles and you never had a problem. But because you read it on a message board, suddenly Fram filters are crap.
I'm not trying to bust balls. I change oil/filters a lot in all my vehicles. I usually buy whatever's cheap at the parts store, which is often Fram. Never had an issue in 25 years of changing oil. That's just me. I've got nothing for Fram in particular, but nothing against 'em either.
It is not that Fram filters are pure junk that cause all kinds of problems. The issue is they are marketed as premium quality filters and in reality they simply are not "premium". Again, not that anyone will experience issues when using them but a really top quality filter cost only a couple of dollars more. Considering what vehicles cost, the length of time I keep my vehicles, I do not mind spending the extra $s to get a premium filter.
Fram = Crap!
Damn near as bad as a K&N in Jeff's world! :lol:
Just kiddin ya Jeff. I've never heard anything good about Fram except that they are cheap. never used them myself.
Fram = Crap!
Damn near as bad as a K&N in Jeff's world! :D
Where/when have I ever knocked K&N Jim??? :lol:
Fram = Crap!
I don't think you have.
It was just a joke.
Fram = Crap!
It was just a joke.
Just clearing that up.
I had a K&N air filter in my 2000 nearly the entire time I owned it and I never had any issues. Though I didn't see any gains (power or efficiency) either, but then again, do any of the others? I doubt it.
    250.3k
    DjmFingerstylePlayer
  • Who's Online   3 Members, 0 Anonymous, 607 Guests (See full list)
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
