redpete Posted April 26, 2009 Posted April 26, 2009 My 2002 Silverado does not blow as much air out the dash vents as it used to. Last time I had this problem the garage replaced the internal air filter. Does anybody have instructions on how to do this so I can do it myself? Thanks
Zembonez Posted April 26, 2009 Posted April 26, 2009 I don't remember the exact instructions but it was pretty easy to access on the passenger footwell down under the glovebox.
bubba33 Posted April 26, 2009 Posted April 26, 2009 located inside the evaporator box under the passenger side of the dash. It will take a 7/32 socket to remove the screw that holds the cover closed.
bossier62guy Posted April 26, 2009 Posted April 26, 2009 My 2002 Silverado does not blow as much air out the dash vents as it used to. Last time I had this problem the garage replaced the internal air filter. Does anybody have instructions on how to do this so I can do it myself? Thanks http://www.gm-trucks.com/forums/index.php?...abin+air+filter It's actually a 7mm socket that's required. Search for cabin air filter if the above link doesn't work, it's been discussed many times.
steelerman Posted April 27, 2009 Posted April 27, 2009 My 2002 Silverado does not blow as much air out the dash vents as it used to. Last time I had this problem the garage replaced the internal air filter. Does anybody have instructions on how to do this so I can do it myself? Thanks http://www.gm-trucks.com/forums/index.php?...abin+air+filter It's actually a 7mm socket that's required. Search for cabin air filter if the above link doesn't work, it's been discussed many times.
