Afm/ Computer Issues
I am new to the forum but have enjoyed ready about all of your trucks.
I bought a new 08 chevy silverado LT supercrew with 5.3l with AFM. I have always owned chevy but this truck and the dealer are about to push me to go buy a ford. I am going to try and explain the problem and maybe you guys will be able to help me explain it to the idiots at the dealership that keep telling me it is normal in chevy trucks.
When I pull up to red lights and come to a complete stop, the transmision will engage and slam the truck forward feeling like I have been rearended. This happened twice while the tech was driving my truck and he still swears it is not a problem. The service manager told me it is an issue that chevy is aware of and it is in the computer and has to do with timing but does not have a fix for it currently. The problem has gotten progressively worse and now I am worried that other parts are wearing and I will get stuck with a 36k piece of crap.
My fathers 2500 does not do this and neither does any of my buddies trucks. I am the only one that has the AFm and wonder if that has something to do with this. Maybe a tune turing it off will hel
GM doesn't make a "supercrew", that's a Ford. Interesting how someone who has "always owned chevy" would make that mistake. :thumbs:
And FYI, this is common and certainly nothing to worry about and it has nothing to do with AFM.
You have a 5yr, 100K mile drive train warranty. Even if it takes a while to come up with a "fix", you'll be covered. Make sure you have proof that you've brought this issue to their attention and keep track of your visits and you should be fine.
Your right, I meant to say crew cab.
BTW, mine does this too, always has. Doesn't bother me anymore. I also had my AFM turned off (for other reasons) and it had no effect. I believe it's in the tranny, but one theory is the slip yoke.
:thumbs: And welcome to GMT!
Like others, I have had this same issue, I too thought I got rearended a couple of times. If it breaks something, I'll be pissed, but if nothing happens, then I'm fine with it.
It is,Theres a bulletin on it on lubing the slip yoke splines.
Welcome aboard!!!
We started noticing this in our TB, it has happened twice now, but its only the v6, and it (obviously) does not have afm.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
