What Color Would You Get?
Soon enough I am going to get me a new truck. I am going to try to get a 6.2l SLT if I can. Basically, I am down to 3 colors I all like: Summit White, Midnight Blue Metallic, and Black.
It's hard trying to decide.. For one, I like all 3, and two, each one of them has their pro's and con's to me. For example:
White - Pro's: Neutral color, easy to keep clean, not to hot in the summer. Con's: White vehicles are everywhere.
Midnight Blue: Pro's: A very nice looking color, fairly rare color (so you won't have what everyone else has). Con's: Kinda hard to keep clean, and IMO, doesn't look great with chrome..
Black: Pro's: Looks GREAT when clean, looks great with chrome. Con's: HARD to keep clean, and is hot in the summer.
Which would YOU get? :lol:
had a dark colored truck already... now im LOVING the white!
But my favorite color is the Stealth Grey Metallic- i would've got that if i had a choice.
Plus i like the name "Summit" white :lol:
Ahh....I'm going to say Black,Don't know why :lol:
Carbon Black Metallic. It won't be quite as hard to keep clean and nice as Onyx Black. :lol:
+1 That's what I ordered. If you wait till Monday I'll have pics.
That would be great, I havn't seen any decent pics of the Carbon black, the only one I have seen is one covered in snow and ice... Havn't seen one clean.
Anything...as long as it is dark blue
Definitely a good choice too. I have always been a fan of dark blue trucks.
Do you have any better pictures of your truck? As in different lighting? I always thought it looked black in your sig picture. :lol:
I am going to look at the blue tomorrow at my dealership.
Do you have any better pictures of your truck? As in different lighting? I always thought it looked black in your sig picture. :D
Yep, in my GARAGE, and multiple threads :lol: I like pictures
The thing with that color is.....It always looks like it has a coating of dust on it :lol: At least the one sitting in our showroom right now looks that way :D
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
