Dead Battery - Avalanche
So, I came out to my Avalanche at noon and it would not start. The battery was dead, not even the dash lights would come on. It was like the battery was disconnected ? I got a jump from one of the others in the office and after about 2 min of charging she started right up. I went straight to the Dealership and they tested and after about 3 hours, said; there is nothing wrong with the charging system or the battery ??? They said, maybe I left the radio on !!! I said, that I could have left the lights on for 2.5 hrs and it should still start, if the battery was good...
I talked with a friend of mine who works at a parts store and he said, he's heard of that problem before with GM vehicles. Anyone else had this problem and what is the fix ???
Thanks
Bill
Thanks
Bill
There are electronics on the new trucks that will drain the battery if you do not start it in a week. When was the last time you drove it for more than a few miles?
Thanks
Bill
Try Searching. There is quite a bit on this mystery.
Thanks
Bill
There's a lot of discussions, but no fix. Mine was at the dealer 3 times for this problem from December to end of January. It all started when I put a new battery in, since my old one wouldn't start in the -20° temps.
I don't know what fixed it, but the last time they said they pulled off and inspected all the cables to and from the battery. I always suspected it was a bad connection somewhere I couldn't see.
Does yours start up if you 'wiggle' either of the battery cables? Mine usually would.
Here's some light reading on it. http://www.gm-trucks.com/forums/index.php?showtopic=88383
Good luck :thumbs:
The truck is normally driven daily for work. It had only been sitting for 2.5 hrs, when it wouldn't start. There were no warning signals on the dash and the gauge indicated a good charge.
I have let her sit in the garage for more than 2 weeks and she started right up. There must have been something that drew the battery down. I believe one of the module stayed on or woke up to bring it down.
Bill
Bill
Battery cable isn't shorting out is it? :thumbs:
http://www.camaroblog.com/blog/1020496_201...ery-cable-issue
What a wonderful first recall for the Camaro.
I'm not sure how the interior lighting works in the new trucks, but I have heard cases of glove box lights staying on to drain a battery. Myself, I left a dome light on in my '98 K1500 and killed the battery. Didn't leave one of these items on in the morning did you?
ive heard of it too, I think it has something to do with the Battery rundown protection feature they have. I came out to a dead battery and even touching jumper cables from one car to the other would make it start right up.
All 3 of the Silverado's I have owned in the past had that problem, and the dealership was never any help. In each case I just put a battery disconnect like they do on the race cars, and I haven't had a battery go dead on me for the last 3 years. I had always suspected something to do with my On-Star, because it is always on technically because of the satellite always tracking where your vehicle is. I don't think we'll ever figure that mystery out, good luck your gonna need it!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
