Weird Sound "clunk"
When I take off I hear a clunk and when I come to a stop it clunks again, like its going back and forth.
2003 hd 2500 2wd 6in lift 35's 6.0 gas.
Can this be the lack of ladder bars?
Slip yoke... Drop the drive shaft and repack the slip yoke splines with grease, re-install and the noise will be gone. Very common problem.
This is my first chevy truck in about ten years so I'm not sure at what point in my 7'-6" drive shaft the slip-joint would be located.
Is it at the boot where the center carrier is located? It looks like it. I'm gonna go tear into it I'll let you guys know.
I think the slip yoke is on the end of the shaft. Hopefully somebody that has done this can let you know before you start.
Wow a freebie thanks!
I used synthetic marine grade wheel bearing grease (for my boat trailer) inside the slip yoke eplines on my 01 and the noise went away for a long time.
Welcome to the ZOO!
Creative naming 101 graduate, I see. :thumbs:
Welcome to the ZOO!
Creative naming 101 graduate, I see. :(
Lets just say it's not my first forum rodeo. :lol:
Welcome to the ZOO!
Creative naming 101 graduate, I see. :withstupid:
I think he's the professor, not a student. :D
It where the driveshft slides into the tranny output shaft.
This is incorrect, think about it if the center carrier is bolt ed in place then how would the driveshaft slip on and off of the tranny output shaft. And since the yoke at the end holds in your tranny fluid I'm sure the heavy grease would contaminate your fluid.
It's right after the center carrier inside of the boot, thats why there is a boot to allow the shaft to slide in and out of the yoke. Simply grease the splines of the male side and the sound is gone.
