Stock Remote Keyless Entry Problems
2001 Chevrolet 2500HD 8.1 silverado
Just this past month I have been having problems with my stock key less entry remotes not working all the time. They only work about every other day. When they work I could lock/unlock and use panic button, and when it doesn't work none of them do. The distance from the truck doesn't seem to affect it either, Ive tried to use them inside the cab. Both remotes are doing it and I changed the batteries. Anyone else have/had this problem? Any suggestions?
  • 3 weeks later...
Actually I have purchased some wireless products for use at my home which had the same problem. Sometimes they would work, many times they would not work.
These were wireless temperature sensors and a TV wireless remote to another room (control TV box from another room).
Being as I know electronics, I was able to convert these to "wired" gizmos and ran wire through my house for these. I've not had a problem since.
One of these gizmos had a little light to indicate it was receiving the signal from the sending unit. The light would be on pretty much constantly unless I placed aluminum foil around it to block all outside signals. Then the light would go off.
What this means is there is a constant stream of these wireless signals in my area which were jamming the receiver. This is sort of like loud noises and you can't hear what someone is saying because of that.
The thing is I live in a rural area! Way out in the middle of nowhere. But there are other houses around me.
Try resyncing your remotes using the instructions posted in your owners manual.
    • So, my 2021 only gets radio updates, right? If that's the case, my radio is doing just fine and probably better off without any updates, especially considering the problems I've been reading about after updates were performed.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
