My truck has the 4l60E and from what Iv read on the web its not too good. Is this true and if so what trans woud be the one to go with? and while im thinkin about it are the rear ends any good ? my truck is a 06 z71 5.3 not sure wut rear it has.
yea im takin care of it but I put i lil into the moter and was wanting to do a lil more. and i heard the stock tranny is only good for like 360hp.
If it is properly taken cars of and not constantly abused, and hooked to a fairly stock engine, it should last AT LEAST 100,000 miles, if not much more.
Corvette servos will help it to shift more quickly and minimize clutch and band wear during shifting.
What mods are you planning to do to the engine to get it so powerful it will destroy the transmission?
At this point...since as far as I know...you only have a tune...I would recommend driving it till you do a lot more mods to the engine or until it breaks, then replacing it with a purpose built, heavy duty, transmission.
thats what im saying also the tranny has 100k on it now was wondering witch one to buy to replace it. the the 4l80 or the l65 or wut?
The 4L65E will bolt right in. Or you could have yours rebuilt with L65 parts when the time comes.
