A-pillar Pod Code Reader?
It's been a while since I've been here but I remember seeing a digital guage that would fit in an a-pillar pod last time I was here. It would keep up with several different settings such as temp, trans. temp., etc and it would also read and clear trouble codes. It plugged into the port under the dash.
Does this sound familiar to anyone? Where can I find one?
Thanks
Volt
probably mine, interceptor aerogauges
www.aeroforcetech.com best you can get.
I 2nd the Interceptor Aerogauge. I had one in my YukonXL so I could keep an eye on the transmission temperature when towing.
There is another type, scangauge I believe, but it's a rectangle shape.
Here is what the interceptor would look like once installed (picture from our good friend Trey):
YEP! That's it! This site rocks.
Now for another question. I like the look of the dual gauge pod, so what other gauge should I get to go with it? I read a thread where someone was talking about a vacuum gauge being helpful?? What would you fellas recommend i get to go in the other gauge pod?
This is going in a 04 GMC Sierra 1500 Z71 with the 5.3 engine
Thanks again for all the help
VOLT
I got two of the same gauges, you can see pics in my garage, that way you can have 8 different functions to cycle thru
OK. Help out a noob here. How do I get to your garage?
Also, does anyone make a double gauge pod that replaces the a-pillar or are the all the type that goes over the existing one? I'm looking for the cleanest, most factory looking install I can find
Thanks
VOLT
I have the Interceptor as well. I will see if I can get Justin to run outside and take a pic, I have the dual A-pillar gauge pod with a DM-100.
Lazyass! :drool:
DM-100? Again, I'm a noob here so please be patient.
Lazyass! :crackup:
It is raining! :drool:
No worries. I am running two gauges, the Interceptor and a PLX DM-100. The PLX is my wideband gauge (plus many more things) and is probably overkill if you are running a stock truck.
Yep. My truck is stock. i have a Magnaflow exhaust and drop in K&N filter. Been thinking about getting a tune from ya'll though. Other tan that, it's just as it left the factory. I do some towing with it on a regular basis though. I am wanting the Interceptor for its code reading and clearing abilities. Maybe I will put a trans. temp. gauge in the other hole on a dual a-pillar pod.
Anyone know how much trouble it would be to hook up an autometer (or similar) trans temp gauge? Any instrustions would be awesome
Volt
The Interceptor will do your tranny temp (main reason I got it). It is really easy to hook up, just pop it into the OBDII port.
SO I really just need one gauge. 2 looks better but I can't think of anything to put in the other pod
You could run two Interceptors if you wanted, but really, you get all the info you could need in one. If you plan on running FI you could run a Boost gauge!
