Nbs Bose Helpful Info
I have been wanting to add an amp to the factory nav with bose in my 2009 since I bought it.  Since day one I was never satisfied with the sound quality of the bose, or the loudness of it.  I have searched high and low trying to find amp info, and how to wire in an amp to the bose.  I didnt really want to buy the expensive adapter either.  So I finally bought speakers and an amp and dove right in.  I was able to wire a Scoche line out converter under the cup holder/ tray on the center console.  (this is where the factory amp harness is)  And for those of you looking for an amp turn on signal, I found a very good source for this as well.  There is a white wire on the plug that goes to the factory amp.  So i tapped into that wire for my amp turn on.  As for wiring in the line out converter it is very simple.  On the harness when you peel back the wire loom some, you will see 4 sets of wires, two in each that are braided together.  These are the door speaker wires colors listed below.
RF Speaker +/- lt. green - dk. green +,- radio harness or amplifier
LR Speaker +/- brown - yellow +,- radio harness or amplifier
RR Speaker +/- dk. blue - lt. blue +,- radio harness or amplifier
LF Speaker +/- tan - gray +,- radio harness or amplifier
I have been told not to wire after the factory amp, but I tried to wire before it (behind the head unit) with no luck.  These wires I tapped are after the bose amp, but there is no chace of damaging anything I have already proved that.  I just used the little wire taps that "t" into a wire that are crimped on to tap into the factory speaker wires.  Some people think this is ghetto I know, but this is quick and easy, and your not cutting the factory wires, so going back to stock is still an option if you ever decided to remove your audio for trade in...  I then ran about a foot of speaker wire (4 ea) to the line out converter.  Then I ran the RCA's under the carpet to the back wall to my amp.  Well I hope this helps some of you guys out there.  Let me know if you have any questions I will be glad to help the best i can.
-Kurt
  • 3 weeks later...
Good information.. Does the amp filter any of the low frequencies from these channels? I was thinking about simply taping in to the 4 wires going to the bose sub, and connecting to high level inputs on the new amp.
yYes the factory amp does cut out low frequencies as the volume increases. I installed a MTX RE-Q5 (more affordable version of the JL Audio Cleansweep) and it sounds amaing now.
  • 5 months later...
Awesome, I appreciate the info. I plan on doing the same thing, but will only be adding a sub. Do you think I can also access the sub wires under the cup holder? I've heard removing the whole console was necessary and wasn't too excited about that, thanks.
Dave
2008 SD with bose
  • 3 weeks later...
Did the install this past weekend myself using the re-q and it went very smoothly. All the wires I needed to tap into are right underneath the cupholders so there was no need to remove the whole console. Mounted the re-q in the center console which fits nicely... Have a 12" sub in the back now and the stereo sounds 10x better.
Excellent. It really improves the sound with just an amp and sub. That pitiful 6" underpowered bose sub sounds like crap. At least you can get some good punch just replacing that. Door speakers and an amp would add another big improvement but that is a much bigger undertaking. Good job!
  • 3 weeks later...
Is the bose amp accessible through the center console? Does anyone have a complete wiring diagram for the Bose amp?
Mine required pretty much removing the center console to get access.
HERE is a link to an 08 schematic. Word of warning, it still took a while to figure out my 08 as it was not exact.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
