Front Brake Squeak
I replaced my front rotor and pads yesterday. I replace them with aftermarket rotors and pads. They were fine yesterday but on my way home tonight whenever I make a left turn the left front brakes squeak. They dont seem to do it in a straight line just turning left. The pads I took off the inside pad was twice as worn the outside. Any help would be appreciated.
STUCK CALIPER! Lube the hell out of the caliper pens with high temperature grease (specifically designed for the job). Make sure that thing is sliding nice.
Took it back apart this morning. The left side pins are fine but I felt the inside pad slide super hard. Cleaned behind clips and reinstalled. The right side had a pin froze up. Removed lubed and reinstalled doesnt seem to be doing it but will see when it gets hotter. Seem to do it more when hot.Thanks for your help man.
    BigJake
    BigJake
  • Who's Online   3 Members, 0 Anonymous, 578 Guests (See full list)
