2008 Silverado Problems
Condensation is normal from an A/C unit. This is the same as the droplets of water which form on the surface of a cold glass of water. The higher the humidity, the more condensation you will get.
As to the door locks, check your fuses. There should be a section in your owner's manual on fuses. Here is how to check them...
http://www.dinosaurelectronics.com/Test_Fuse.htm
i mean water pours all out of the dash, its crazy
That is not normal. Get it checked out ASAP.
