Gmt-900 Add-a-leaf Question
I bought the Tuff Country Add-a-leaf kit for my 1500 a while ago and havent gotten around to installing yet.
Am I going to need longer u-bolts? I have about 3/4" of thread left. If I do, anyone have a guess as to where I can get some?
Will I need new spring clamps? If so, anyone have a link to some good ones?
Tuff Country should supply the needed hardware. I would start with them.
Already called them, werent of much help. The tech said that he "thinks" the u-bolt will be long enough.
I'm looking for people how have installed an extra leaf on their trucks. I'd like to "know" if I need a longer set of u-bolts before I get half-way through the installation.
Yeah, the leaf itself is no more than 1/2" thick. That should be fine since the middle single leaf spring bolt is what compresses the leaves together, right?
Not sure on the spring clamp issue though.
For what its worth... you're not supposed to re-use the axle U-Bolts (although I have before, but they really are 'one time use' so if you can get your hands on some new ones, there's no reason not to)
Most of my local auto-parts stores sell the spring clamps... pep boys, autozone, advance auto, etc. Worst case, do a quick google search and order a set
I reused my stock u-bolts but the kit came with a new centering pin so I used that...My kit came with spring clamps too but I couldn't figure out how they went on properly so I didn't bother at first, now someone threw the damn things out not long after I did it..
Id get spring clamps, mine keep wanting to slide out. Pisses me off. Im going to order new clamps soon.
Thanks, finally found some locally. Maybe one day I'll actually find some time to install the damned things.
  • 3 weeks later...
i got the super springs for mine because you can adjust ride heighth and load capacity with very little notice to ride difference. I installed a set of add a leaves on a 97 Z71 I had and they had a hole in the center of the spring that matched a nipple on the block that retained the spring to prevent sliding and it came with clamps to prevent twisting sideways as well. They were Pro Comps, that was a while back though!
    • Any update if the new valve cover help with the oil consumption?  I have a 2014 GMC sierra and my truck is consuming a lot of oil so I’m wondering if replacing the driver side valve cover will stop some of the oil consumption. Thanks
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
