Sunroof Deflector... Do They Work?
I'm finding on my Sierra when I crack open the sunroof, I'm getting nasty standing waves in the cabin which gives a pretty annoying "whommpf.. whoommf.." sound that hurts the ears.
I noticed that my old Acura and my BMW both have a plastic comb piece that pops
up. Until now, I didn't know what that was for, but it actually breaks up the airflow, so you don't have the issue.
I'm wondering if I put on a deflector on the roof that the noise would go away?
Mine has a fabric wind deflector that pops-up,No wind buffering at all,Its pretty quiet.
Mine too has a small plastic deflector that pops up and I haven't noticed any wind noise like that.
This happened to me once so far in my Escalade. I'm pretty sure those deflectors eliminate that problem.
Mine has a deflector and I don't have what you are describing.
Obviously I have more wind noise when it is open, but no buffeting like you are talking about.
At highway speeds...Mine makes more noise when it is just open a little bit, than it does when it is fully open.
Yeah, the built-in deflector works fairly well. I mean, just push it down, and you'll see what I mean. :thumbs: But I'm normally driving at slower speeds if the sunroof is open, otherwise it's just too noisy.
My '85 prelude has a pup up deflector...driving 60 miles an hour you cant hear any of the noises youre describing, however if I push the deflector down the wind will start that whooompf noise like youre saying, so yes, thats the problem.
I've been trying to think of things that would effect the airflow over the truck. Do you have anything attached to the front of the vehicle (the hood perhaps?) or covering the bed? Have you done any interior modifications (sound dampening, perhaps?) that might've covered up some of the venting that GM builds into the vehicles?
Nothing on the hood, just a rollup toneau cover on the bed. Nothing blocking vents. Interior was left stock. I'll check it again, I don't think there is a pop up deflector (I know what you mean though). Maybe it's defunct? :)
Alright, I was just curious.. There "should" be a pop-up deflector on your's. Maybe it is stuck down or missing or who-knows-what.. Also, have you tried the sunroof experiment with the tonneau rolled-up, just to see if it makes a difference?
Hmmm. armed with a beer I hit the garage. When I crack it open, there is a pop up "comb" that I was wondering about. I'll have to take it for a drive once the rain stops and see if it works. I'm 99% sure nothing was popping up the other day when I was getting those standing wave issue..... :)
If it's not always popping-up, I think I'd take that in to have it looked at.. Better safe than sorry, especially if something is binding-up. You don't want a leak, on down the road.
Thanks for the advice. Totally forgot to even try the sunroof today when I was out. I'll try it with the toneau rolled up as well. Looks like I have some "driving around looking busy" on my hands!
My wifes Explorer has a pop up deflector on her sunroof and she definately gets that sound, but only at slower speeds. After trying everything imaginable to get rid of it, I found the only thing that works is to open one of the windows about 1/4". Let us know if this works for you
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
