Impressions After 2500km
Hey guys, I have just over 2600KM on my new Sierra and thought that I would share my thoughts. Feel free to comment.
1. The brakes suck. My '86 3/4T stopped better. Soft pedal at first, press again and it's hard.
2. The cruise control is a joke. I'll gain 15-20KM on a 6% downhill grade, or lose at least 10KM on the uphill. Funny thing is that it doesn't do it all the time.
3. The truck is averaging 15.5 MPG; I hope that will start to improve.
4. It has more balls from the 5.3 than I was expecting, sounds not too bad either.
5. The interior is well laid out, IMO, from the driver's seat. The CC back seat is huge.
6. The truck looks great with the GAT package.
All in all, I am quite happy with the purchase (even though the check engine light came on- error code PO335- yesterday. Dealer cleared the error as it would not repeat and said don't worry about it). The guys at the Langley Line-X store slopped some sticky paste on the box sides and tail gate that wouldn't come off. They tried to deny it was them (had only 200KM on the truck) but they did get it off and scratched and discolored the paint in the process. They paid to get it detailed, which took care of it for the most part.
+1 on the brakes not being so great...my '05 was way better. In my opinion, the cruise control issue, which I noticed right away too, is caused by the AFM going to V-4 mode and losing speed then kicking in and out again. I'm sooo glad I got mine disabled! Much better truck without it and mileage is unchanged.
Pretty happy with my brakes so far, much better than my 97 Sierra was!
Cruise control, I haven't noticed that trait yet but I will try it this wknd on my hilly drive to the trailer.
Power is sluggish off the start but seems to be improving (2,800kms) as is my gas milage, I travelled at a fairly decent clip on the way home from our trailer this past wknd and was quite surprised at how little gas I burned when I got home!
So far I love my truck, got a few things looked after at the dealer's last week and nothing new has popped up so hopefully it is just clear sailing from here on in?
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
