Codes P0053 & P0135
walkerdog
my check engine light has caem on and throwing these 2 codes . where should i start? i don't want to change the oxygen sensors and that not be the problem . the probable causes show
short circuit
relay defective - where is this relay
oxygen sensor (SENSOR 1 BANK 1)
This is a heated oxygen sensor and the computer is detecting that there is a problem with the heater portion not working. And the other code is caused because the heater is not working.
This could be a fuse, wiring, a connector with a poor connection, or the heater in the oxygen sensor (replace oxygen sensor in that case).
Generally oxygen sensors should be changed every 60,000 miles as a regular maintenance item. And when I replace mine, I get better gas mileage (also my engine is more lively). So I see this as a money saving thing myself.
But just about everyone I know will REFUSE to replace their oxygen sensors for some reason???
Anyway information for troubleshooting and/or replacing this would probably be in an aftermarket repair manual for your vehicle (auto parts store). But this information would for sure be in a Factory Service Manual set for your vehicle which you can order from your dealer.
  • 3 years later...
Sorry to resurect an old thread, but is there any way to tell which sensor is bad?
The P code will direct you to the sensor. Bank 1 Sensor 1 is the drivers side, pre-cat O2 sensor. Sensor 2 would be post cat. Bank 2 is passenger side. The bank #'s tell you cylinder side #. #1 cylinder is driver side. #2 cylinder is passenger side
All my Autocal tells me is P0053 or P0135. Is there a way to decode that further or will I have to carry it to my mechanic?
Ill probably just end up replacing all 4(106K and probably still the factory sensors), but Im just curious as to how I could determine which sensor went bad.
Also, which brands of sensors do you recomend avoiding? Ive noticed the Bosch seems fairly reasonably priced (cheap). I also know that with most products, you gt what you pay for, but I dont want to overspend for no reason.
I always try to use OEM. With that being said the last one that I replaced was on my wife's Pontiac Montana van. The sensor was the one that came from the factory. And I replaced it with a AC Delco. A couple of weeks after I replaced it I looked at the old one with a magnifying glass. It had the part # etched on and made by Denso.
Rock Auto listed Denso as the factory manufacturer for the O2 sensors. I hope there isnt a difference between the different positions because I just bought 4 of the same sensors. They only listed a single part number, where AC Delco listed a different one for pre-cat and post-cat. is there a difference? If so, Im gonna have to cancel my order.
Thanks. It never occured to me to look, but with the rain we got yesterday and the day before, I probably wouldnt have looked underneath it anyway.
