1988 GMC truck brake light problem. Turn the lights on and the tail lights come on but no brake lights when I push the brakes. But if the lights are off and I hit the brake they light up. Any suggestions?
You could try activating your hazard light switch a couple of times. On/off.
Then try removing the bulbs in the rear and reinstalling them. Might try cleaning the sockets with a paper towel.
Then disconnect/reconnect the wiring harness connection under the rear of the vehicle. If trailer lights tapped in, examine that wiring closely.
Other than the above, you will need a wiring diagram and a multimeter to test and find the problem.
