Predator Programmer
After 2 days of driving after my Predator reprogramming I must say I am very happy with the results,I have better throttle response and more power, plus better shift points and after a little adjustment the perfect shift feel. :thumb:
I had the Hypertech programmer before this and in my opinon was a total waste of money: the shift points sucked, little or no power increase and seemed to suck down the gas and cause poor TCC engagement.
I have'nt tried the Superchip Programmer, but with the ability to make your own adjustments, I think for the money the Diablo Sport Predator is the only way to go!!!!! :lol:  :lol:  :eek:
I just read the GM install guide for your Diablo Sport Predator .  Man you must have some DEEP pockets.  You need to run their power tune setup with Super unleaded gas ONLY or risk damaging your truck.  No power tuning with regular?  To add to that you need to run your truck in TOW/HAUL mode in order to have the power tune running correctly?  Too many hoops to jump through for me.  I'll stick with my Hypertech.  But I'm glad your happy with it.  Anyone else have a Diablo Sport Predator?
Derek, I obviously don't know what your experience/knowledge levels are, so I'm not trying to insult you...just don't run your engine too lean and start burning your pistons and stuff.
:crackup:
A. As far as having to run high octane fuel, I have been running 89 octane since I have installed the program with no ill effects
B. I have never had run the truck in tow/haul mode to gain performance from the program.
C. As far a running the engine lean and causing piston damage that would be about impossible to do unless you go tinkering with fuel delivery,and even if you did have problems you would easly notice a spark knock or detonation problem way before any damage could occur, which could be fixed by running a higher octane fuel or a colder thermostat
D. If you own a Hypertech programmer and believe you are getting any performance gains in anything than full throttle operation you have been mis-led (you either didnt read between the lines of how the programmer works or have been mis-informed on its capabilities)
Hypertech= :banghead:
Great.  Well I guess rules were ment to be broken.  Please keep us updated with your Predator as I'm intrested in your long term experience.  Seems pretty cool however except for what I pointed out as per Predators instructions.  But if it works as you say it does then I'll switch. :banghead:
I just got a Diablo for my blown 5.3 Tahoe.
You  can run 91 or 93 octane,but that is necessary with ALL programmers due to more timing=more power.This is the reason for higher octane fuel. A normal proceedure for all motors.Hypertech is only done on WOT only.I do not drive like that ever day.
Also you do not have to adj shift in tow/haul mode only,that is so you can adj that system also.
So as you can see the Diablo is a little more advanced and lets you do more a fine tune to  your vehicle overall.
If you have more than stock mods like me this is prefered .
I will be going on the dyno to get my proven results with Diablo. :thumb:
Super Jet Dyno Controlled runs...
Stock with cat back=243 RWHP
Whipple program=287 RWHP
Diablo Sport program with custom tuning option=337 RWHP (with 2.5 adj to fuel at WOT and a/f ratio at 11.8 also adj timing 10% advanced with no ping on 93 pump gas.)
SAE numbers=404 HP
Now I got the real to the pavement 100 hp I was looking for !!!  :hail:  :D  :cool:  :thumb:
SAE numbers=404 HP
Now I got the real to the pavement 100 hp I was looking for !!!  :hail:  :sleep:  :D  :thumb:
Sounds pretty friggin amazing....
if only I could afford the blower or the predator.....ahhh dreams :cool:
I have a '97 GMC Yukon with a cam and other performance parts.  The truck surges at idle in gear pretty bad.
Can I adjust the desired idle with the Predator?
How much does it cost?
Thanks.
Forget the Predator.. Go with a Westers Performance PCM.. they recommend you use 87 Octane and your vehicle will run circles around someone elses that has a predator or a Hypertech
Where do I find one of them and what is the cost? :chevy:
    • Sounds like converting will be a bigger endeavor than I was thinking. This truck doesn't have 2Hi like the Suburban did. The Tahoe has 4Hi and 4Lo and a button to turn of traction control.   From what I understand the Stabilitrak uses open diff in the front and rear. When wheel speed is not the same the stabilitrak uses the ABS system to slowdown the spinning wheel(s) to transfer power to the slower non-spinning wheel(s). I thought the transfer case was open too. Being able to transfer power either more to front or rear depending on wheel spin. Maybe I miss understood some information with you saying and power transfer is 50-50. Thanks
    • My brother has a 2007 Avalanche with afm 5.3. It`s got 176,000 miles. Runs like a clock. Never been apart. Co worker has a 2010 Tahoe with afm 5.3. 230,000 miles. Never been apart. Runs like a clock. So, even though cyl deac is a weak spot, they can go the distance.   BUT, these engines had the oil changed regularly, AND had 5w30 as spec. I wonder if they would have lasted this far on 0w20? I`ll bet not.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
