Oil Sample Results "break-in" Oil Change
Well here are the results. This is typical of the engines I have bought new, or the ones we build here. Wear metals high, some silicon (dirt). This is why I change it at 500 miles or 50 hours. There is nothing wrong with the engine, this is normal. I simply don't want this stuff in my engine. Engines are not built in a "clean room". I will take another sample at 3000 miles.
oilsample.pdf
oilsample.pdf
oilsample.pdf
oilsample.pdf
Thanks for posting the results,Thats interesting to see.
I'm like you,I've always done the first oil change on my trucks around 1,000 miles.
I had similar test results on my first change at 1500miles. Copper and silicates high. I believe the copper is from bearing wear-in and the silicates are leftovers fro the casting process. Changing the second time at 5K to see the test sample. Then I will decide when to actually change going forward.
Yeah that is why I cringe when people talk about going 10K on the first one, if the copper/silicon particles are smaller that 30 micron some filters arent catching them...yet the same individual will give me a hard time for going over 3000 rpm during the break in period. No rants, no hard line, just don't like the idea of it in my engine. I like the oil samples to come back clean :shakehead:
