Do you have interior cabin creaking?
My 03's interior creaks whenever I go over a rough road slow or on a backroad. I have the extended cab. It makes the truck feel very cheap. My fathers 01 is far worse. And my 99 Reg cab was rock solid with no interior noise. Anyone else have this problem?
No creak at at all, yet. Very tight, very quiet... Take it to the dealer. These things should be very quiet vehicles.
Its a GM plastic snap-together truck, a little creaking is expected - gives it character. I tracked down most of the noises in my truck and fixed em with felt and glue and what not, but new ones are bound to appear. The only real noise I have anymore is a rattle in my seat from my subwoofer kicking the crap out of it from behind, don't think there's a whole lot I can do about that one though :D
Some of the noise could be coming from the door seals (rubber weather stripping), especially where the front and rear doors meet. A little Silicon Spray, or di-electric grease might cure some of the noises you are hearing. I think there is some body "flex" in that area, and you can hear things rubbing. My crewcab has a "B" pillar, and I don't hear that noise at all... but my '00 excab made alot more "moans and groans".
I think it is where the doors come together and with body flex you here the creaking. I will try to track it down with some silicone and felt. I am thinking about putting a roll cage in it to stop the body flex :D
It is absolutely the weather strippings in the door seals. What you need to do is go to Wal-Mart and buy a can of STP silicone grease (blue can, red top, kind of like a spray paint can.) Pull your weather stripping off (driver and passanger side)...I am talking about the strip that runs along from the front fenders, up the windshield, and then across the edge of the roof, then down behind the rear doors. Wipe them off with a dry rag (to get the dirt off) and then SOAK both sides of them with that stuff. It is "greaseless" and odorless, so don't worry. When I say both sides, I mean the side you can physically see, and the side that actually touches the truck. I had mine in the shop 3 times for that problem...and the truck sounded like a piece of s**t from day 1. I wanted to get rid of it because it sounded like it was 30 years old from all the noise the cab made. All the dealership did was spray the side you can see. After a year of living with the noise, I started thinking that maybe it was the backside of them. I soaked them, put them back on (real easy to do) and haven't had a problem since. That was like 3 months ago, but I'll do it every 2 weeks if necessary. It feels like I am driving a brand new truck, even though it is only 1 1/2 years old. Good luck, and I feel your pain!!!
mine is horrible. Id say the worst thing about my truck is the squeaks and rattles
I've been wondering what to do about my creaky silvy. Thanks for the accurate post and procedure. This place is great!!! :D:flag:
Hey Seadoons, thanks alot for the tip! I will try this this weekend. How long did it take? Does the weather stripping pop in and out easily?
Thanks
I'd like to add that my 01 Sierra XCab has the same problem. Dielectirc grease did the trick! It only seems to last for about 3-4 months however. Has anyone noticed the rubbed paint and rust below the threshold, where the lower weatherstripping on the doors rub the paint?
It took all of about 10 minutes to do this. They pull off real easy...and putting them back on isn't too hard either. When putting them back on, start just above the windshield, and then slide it down behind the fender (be sure to note their position before taking them off and you'll see what I am talking about). Snap it back on along the windsheild, along the roof, then down behind the door. I am not mechanically savvy at all, and I am not a big fan of ripping things off, but it was very easy. I did it like 2 months ago, and I have had no problems with wind noise, leaks, or the strippings not staying on. I bought the GM dielectric grease, but I did not use it. The little tube was $14 from the dealership, and the can of silicone grease was really cheap at Wal-Mart. The way I figured out it was the strips making the noise was that I pulled them off and drove it around the block. It made my day...it was so quiet!!!!! Anyone that thinks their truck is a POS because of all the noise the cab makes needs to try this.
Trucks lacking b-pillars of all brands are notorious for creaking.
Be careful with interior parts too. We damaged the latch for the slider on the Ranger and now it will not shut up. On the Blazer my cousin owns, one of the door panels came loose from the door. Some gasket sealer took care of that.
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 433 Guests (See full list)
    • Sure, but they do have some affordable options like the Trax, Trailblazer, Envista, and Encore. Some of these have a cheaper base price than the Civic, though the fuel economy isn’t as high. The main problem is that people WANT the highest trim with all the goodies and finance for like 7 years. That’s how ppl “afford” the more expensive vehicles.
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
