Leveling Kit, Rear Blocks, What Tires?
athenstiger
I'm looking to add a ReadyLift 2.25 leveling kit along with 3" rear block kit to my 2009 Sierra Crew cab 4x4. What tires would you recommend? The readylift site says 33" tires, but I'm having trouble finding the right size with my 18" rims. Please give me some brands and sizes to choose from. Thanks in advance for your help.
Adam
Right now I have the rough country 2" lift in the front on mine. I have after market 18's and have 285/65 Kumho's on them. I think a 285 is somewhere close to a 33" but not sure. here are a couple pics. I think Nitto, Toyo and BF Goodrich might have some in that size.
SierraRR is correct his are 32.58" tall to calculate it you take (285*0.65)/25.4 = 7.29*2+18 = 32.58". You can figure out any tire size height once you know the three key values i.e. 285/65/18 just by substituting the numbers into the formula. :lol:
It's easier if you take a shortcut:
285*65/1270+18=32.58"
In other words, multiply the first two numbers together, divide by 1270 and then add the wheel diameter.
You could always go with 35's :D
I love mine :cool:
So do the fronts rub? :D
A little bit on the frame when they are turned as far as they will go.
The stock 275/55/20 Eagle LS-2's rubbed on the frame too though.
2" leveling kit, 3" rear block.
285/65/18 Nitto Terra Grapplers:
275/65/18 Bridgestone Dueler Revo's:
I love mine :dunno:
just out of curiousity, why did you raise the front and install 2" drop shackles in the rear? why so extreme with the cali lean?
You could always go with 35's :lol:
I love mine :smash:
i was wondering the same got me confused
I just ordered the same ReadyLift set: SKU 66-3085 (2.25" Front Kit) and SKU 66-3003 (3" Rear Block)
I plan to put Nitto Terra Grappler LT285/65R18 E 125R on them. I'm currently running Fortera 285/45R22 on the truck.
The Forteras are 32.1" diam., the rim is 10.5", and the tire width is 11.2"
The Nittos will be 32.54" diam, with a width of 11.22"
I don't foresee any problem fitting those tires with the leveling kit.
  • 2 months later...
  • 1 month later...
You could always go with 35's :confused:
I love mine :D
I believe that NorthFlaRedneck has a great looking truck. Any truck that doesn't have a lift kit on it and has 35"s under it are the best looking ones. around here in the rural parts of arkansas the back raked down a hair more than the front on the 4wds is the look you want. im getting a 2010 sierra or silverado in a month and i'll be doing mine the exact same as northflarednecks the same week i get it.
I don't want anything that rubs... If I'm off road and hit a tree root while driving think of what that "only rubs a little at full lock" is gonna do when you hit something...
I agree with sab316, I just ordered a 2.25" readylift leveling kit for my 07 nbs silverado, I was looking at 275/70/18 BFG A/T but I do not want any rubbing or issues when I go off road and the shocks compress.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
