Z71 Off Road Vs Standard Hd Suspension
Having a hard time telling the difference between the standard HD suspension that comes with the trailering package and the Z71 suspension...besides the sticker on the rear quarter panel. I really do not need off-road features, I don't think, as we will use this new 2011 2500HD for pulling our 35' camper.
I am a novice on the suspension stuff so any advice from you who know is appreciated!!
thanks in advance
thanks in advance
In addition to the stickers you also get some plastic skid plates, I think.
I assume you got the DMax. You're going to love how it pulls your camper.
z71= sticker, slightly different shocks and a skid plate the size of a book and bigger bump stops
Thanks for the info...the skid plate package by itself is $125.00, Z71 is $225.00...figure I might as well get the z71, but with out the stickers.
Not ordering the DMax...going with the gasser...can't spend the additional $8k for diesel
That's how I ended up going and the same reason why! I'm happy with my gasser though. If it weren't for all the DMax guys here always talking about how great their trucks are, I would have never known the difference!
:dunno::cheers:
Also, the skid plates are included in the Snow Plow Prep' Pkg.
Is the engine skidplate still alum' & the T/C skidplate, steel? That's what they're made of on my GMT800 ('04).
Some of our trucks have to work for a living. When I checked the 2011 3500HD Dmax is rated at 19,400# in gooseneck service while the equivalent gasser is rated about 8,800# if I remember right. With a gear change, maybe up around 13,500#, but still 3 tons less than the DMax can tow.
I never looked at 2500HD's (I need duals), but a friend said the differences were similar between the small block gasser and the DMax.
With a 35'r, it would be money well spent. Thats a lot of trailer for a 6.0 gas motor.
Mark
Mark
My thoughts exactly. Our trailer is a little shorter, a 34-footer, and weighs in at 14,400#. No way I could pull that with 6.0.
If this 6.0 can't pull 7,700 lbs, then I would stick with the Tundra if it had a better payload. The 2011's Sierra/Silverado gasser with 4.10 is rated to pull 13,000 on a ball hitch and 13,900 with a 5th wheel
By staying with the gasser and gearing it right your okay. The way I always think about it is I can buy a TON of gas for 8 to 10 grand.
For the six or seven times we go camping a year, the gasser will be fine and this 6.0 will handle it just fine. When we retire and travel all the time and get a big 'ole fifth wheel then we'll buy a diesel.
    250.3k
    user087
    user087
  • Who's Online   3 Members, 0 Anonymous, 747 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
