Bfg At/ta Tire Wear
These BFG AT/TA tires seem to be wearing a little odd compared to what I remember when I had the same kind on my old Izuzu. In the pic, I'm referring to the scuff marks along the outside edges of the tread, on the sidewall side. I do drive on some pretty rough terrain, but these scuffs are from street driving. I can say that with certainty, as these marks are since I cleaned the tires this past weekend. I admit that I corner pretty hard, and my foot is always in the pedal. (basically, I drive the hell out of this thing :dunno: )
Anyway, I don't remember seeing this type of sidewall scuffing on my previous AT/TA's. I run 35 PSI, and these tires have about 1,000 miles on them.
Look normal to you?
When's the last time you had an alignment?
Not since I've had it. I just bought it about 2 months ago. It's the same on all 4 tires though.
They look exactly like every BFG AT I've ever owned. The big tread blocks seem to flex a lot when these tires are at full tread depth. (the tread depth is HUGE) It goes away after they wear down some... or at least that's what I've had happen with mine.
Huh. I guess the ones on my Izuzu must have been more worn.
You also have to consider that these trucks weigh a lot more than that Isuzu. They will deflect the rubber in those blocks a lot more because of it. I've always gotten great wear out of BFG ATs on my trucks just the same.
I am not an expert, but I have been running BFG AT/TA's since 2001, and IMHO, 35PSI is TOO LOW!
I have 265/75-16D's so my tires are LT not P so that's why I go with a higher pressure. If you have a LT tire also, I would consider the tire pressure.
I had to go round and round with the tire-tech because he wanted to inflate the tires according to the tire pressure data on the door. Even though it was not the same tire. Just because they sell the tires does NOT mean they know diddly squat about the pressure.
Call BFG customer service and ask them.
Same size. What pressure do you run?
Not a bad point. You might try bumping them to say... 38 psi and see what the difference is.
50 PSI. I have a lot of emergency gear in the back, plus my bumpers add about 500lbs so I have a pretty heavy truck. If I am towing a trailer then I bump the pressure up to 60PSI.
If you are pretty stock, I would try 45 PSI. Make sure they are LT not P metric. Max pressure on LT is 65 PSI.
I'd try bumping up in 3-5psi increments until you get to where you think you should be.
A good test is the chalk test. Put a line of chalk on every tire, and drive around the block (don't hit any puddles). If all the chalk wears off, you're at a good PSI, if the outsides don't wear off, you're too high.
A good test is the coke test. Put a line of coke on every table, and drive around the block (don't hit any puddles). If all the coke wears off, you're at a good PSI, if the outsides don't wear off, you're too high.
huh?
:thumbs:
    • I've had good experience with my Android head unit.
    • You should be evaluating enough comparable trucks to know if one sounds different than the others - if you can't tell something is amiss by ear, it's probably fine.   Further evaluate enough trucks so that you can determine what 'normal' looks, sounds and feels like. Even if this is the first truck you're looking at and want to buy, go look at several more (regardless of whether you intend to buy them).   Insist on taking the vehicle to be evaluated, spend some time looking ALL OVER IT, look for overspray where it shouldn't be, paint damaged on bolt heads that are not normally removed. Check for rust, missing fasteners, non-factory style fasteners, suspiciously new parts especially on non-wear items. Check for leaks, check fluid conditions and level (dirty isn't the worst thing in the world but exceptionally low is).   Ignore tire shine and plastic dressing that makes an engine 'shiny'.    Beware of heavily fragranced interiors to mask odd odors that could hide potential mold from a leaky rear window.   Carfax is barely worth the paper it printed on. DO NOT trust it, a vehicle can be wrecked, fixed by a bunch of drunk hillbillies in their cousin's backyard and still have a clean Carfax. I can meticulously maintain my vehicle at home with top quality parts, materials and methods, the Carfax won't show a thing.   Taking it to a shop to have a teenager working afterschool (an inexperienced mechanic) evaluate it is a waste of time.   Lastly, a good, well taken care of truck will present itself as such, it would be generally comparable to a new truck. An uncared-for truck will show it, dents, scratches, seat stains, paint swirls, tears, scuffs, marks, rattles, vibrations, clunks, miss matched tires, etc...
    • If you suspect an engine swap or similar modification to the front accessory drive...   Maybe try spending some time plugging in different make/models/years that utilized the same engine (prime donor vehicles or swap candidates), vans, full-size cars (Impala, Roadmaster), 4x4 trucks to get a collection of pump and brackets that are similar along with their associated part numbers; take that collection of part numbers to the parts store to compare.   Another Okie.
    • There are knowns and unknowns.   Knowns:   - LT, RST and LTZ names/trims are gone.  The new "Silverado" trim level replaces all 3 of those.  You should be able to configure the Silverado trim to match the equipment levels of those three trims.    Unknowns:    - Custom.  No mention of what engines it will have access to.  Dual exhaust being standard does seem to confirm a V8 option for the Custom trim though.  My "guess" is that Custom will have access to the Turbomax and the 5.7.  I could be wrong though.  The current Custom trim went 2.7 Turbomax only the last 4-5 years, and only had a single side exit exhaust.     - 40-20-40.  I would imagine that is NOT going away.  They only focused on showing the new interior on the top trims, Trail Boss, ZR2 and High Country, hence the images shown are just bucket trucks up front.         The info should start coming fairly quickly over the next weeks and months.  Production is supposed to start up later this year, so when the order guide launches, you'll be able to see the configurations of engines, cabs, seating, etc.
    • I don’t do offloading other than a dirt road literally for me it’s more about the look which I really appreciate a nice looking truck and I like sitting a higher and not just because I’m 5 foot seven lol..  I’m also not compensating for anything lol..  but I truly think it’s safer on the road the higher you sit you have better visibility generally speaking especially a few of your Sideview mirrors adjusted correctly. They do make a programmer rough country does they’re $1000 for these new 2500s but when I do a gear swap that would be a moot point. A lot of the shops that I go to in my area they’re all saying the same thing that Yukon Detroit axle Eaton Spicer Richmond they don’t have gear shot for these trucks which surprises me because hasn’t this body style been out since 2020? I’m hoping soon they have something because yeah I’ll have to spend the 3K to get both axles done. Thank you for all of your response responses. I apologize if there’s any grammatical error errors as I’m doing speech to text on my iPhone without proofreading
