Gmt-900 Torque Specs?
Does anyone have a resource that lists propper torque specs for things like:
-lug nuts
-front suspension components
-rear suspension components
-u-bolts
Havent had much luck finding anything, so thanks in advance.
  • Replies 47
I can tell you right off the top of my head that lug nuts are 140 ft.lb.
I'd have to look the other stuff up...Is it 2 or 4wd?
OK,I went with 4wd,See if this helps you.....
2008 Chevrolet Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Suspension | Front Suspension | Specifications
Fastener Tightening Specifications
Application
Specification
Metric
English
Brake Hose Bracket Bolt
9 N·m
80 lb in
Brake Hose Clip Bolts
12 N·m
106 lb in
Hub and Bearing Assembly to Steering Knuckle Bolts
180 N·m
133 lb ft
Lower Ball Joint Stud Nut
125 N·m
92 lb ft
Lower Control Arm to Frame Nuts
175 N·m
129 lb ft
Shock Absorber Module to Frame Nuts
50 N·m
37 lb ft
Shock Absorber Module to Lower Control Arm Bolt - 1500 Series
50 N·m
37 lb ft
Shock Absorber Electrical Connector
20 N·m
15 lb ft
Shock Absorber Nut - 1500 Series
890 N·m
59 lb ft
Shock Absorber Nut - 2500 Series
24 N·m
17 lb ft
Shock Absorber to Lower Control Arm Bolts - 2500 Series
80 N·m
59 lb ft
Spring Jounce Bumper Nut - 2500 Series
30 N·m
22 lb ft
Stabilizer Shaft Insulator Clamp Bolts
50 N·m
37 lb ft
Stabilizer Shaft Link Nuts - 1500 Series
23 N·m
17 lb ft
Stabilizer Shaft Link Nuts - 2500 Series
23 N·m
17 lb ft
Torsion Bar Crossmember to Frame Bushing Bolt
95 N·m
70 lb ft
Torsion Bar Support Link Bolt
95 N·m
70 lb ft
Upper Ball Joint Stud Nut
50 N·m
37 lb ft
Upper Control Arm to Frame Nuts
190 N·m
140 lb ft
Wheel Drive Shaft to Front Hub Nut
240 N·m
177 lb ft
Wheel Speed Sensor Mounting Bolt
18 N·m
13 lb ft
2008 Chevrolet Silverado - 4WD | Sierra, Silverado (VIN C/K) Service Manual | Suspension | Rear Suspension | Specifications
Application
Specification
Metric
English
Leaf Spring Mounting Nut
200 N·m
148 lb ft
Rear Leaf Spring Shackle Nut - 1500, 2500, 3500
95 N·m
70 lb ft
Rear Shock Absorber Upper Bolt - 1500, 2500, 3500
115 N·m
85 lb ft
Rear Shock Absorber Lower Bolt - 1500, 2500, 3500
115 N·m
85 lb ft
Rear Spring/Hanger Bolt
50 N·m
37 lb ft
Rear Spring Stop-3500
50 N·m
37 lb ft
Rear Stabilizer Shaft Insulator Nut - 3500
32 N·m
24 lb ft
Rear Stabilizer Shaft Link Bolt (Frame Side of Link) - 3500
95 N·m
70 lb ft
Rear Stabilizer Shaft Link Nut (Bar Side of Link) - 3500
53 N·m
39 lb ft
Rear Suspension Jounce Bumper
32 N·m
24 lb ft
U-bolts - 1500
100 N·m
74 lb ft
U-bolts - 2500/3500
160 N·m
118 lb ft
Thanks a million. Where did you find all that stuff?
Yup, its a 4x4. Do they make any 900s with the Z-71 package in 2wd?
I work for a GM dealer.
And yes,You can get a GMT900 2wd Z71.
  • 3 weeks later...
MS3DALE- Rich- since you have that spec book handy, could you possibly give me the torque spec for my 1500 LT1s-
1) rear spring shackle bolts,
2) bed mounting bolts
3) and OEM hitch mounting bolts?
I figured I could just guess,but....
Thanks
The rear spring shackle bolts are listed above,Heres the rest...
Application
Specification
Metric
English
Assist Step Body Mounting Bolts
90 N·m
66 lb ft
Assist Step Center Bracket Bolt
45 N·m
33 lb ft
Body Cable Body Side Bolt
100 N·m
73 lb ft
Body Cable Frame Side Bolt
85 N·m
62 lb ft
Body Mounting Bolt
60 N·m Plus 170 Degrees
44 lb ft Plus 170 Degrees
Crossmember - Front Engine Bolts LD
105 N·m
77 lb ft
Crossmember - Front Engine Bolts HD
70 N·m Plus 110 Degrees
52 lb ft Plus 110 Degrees
Engine Protection Shield to Frame Rail Bolts
20 N·m
15 lb ft
Engine Splash Shield Bolts
12 N·m
106 lb in
Frame Brace to Frame Bolts
50 N·m
37 lb ft
Oil Pan Skid Plate Bolts
28 N·m
21 lb ft
Steering Gear Shield (9D/0320A SHIELD-STRG LNKG)
20 N·m
15 lb ft
Tow Hook to Frame Rail Bolts
85 N·m
63 lb ft
Trailer Hitch to Frame Bolts
100 N·m
75 lb ft
Trailer Hitch to Frame Nuts
113 N·m
83 lb ft
Transfer Case Shield Bolts
20 N·m
15 lb ft
Transmission Mount to Support Bolts
40 N·m
30 lb ft
Transmission Support to Frame Bolts
95 N·m
70 lb ft
Pickup Box Bolt
85 N·m
63 lb ft
  • 3 weeks later...
Wow, the body mounting bolts are only 44 ft-lb? I guess i'm good with the 85 I've been going to :sigh: (it probably changes due to the longer bolts of a body lift... BDS claims 90 and PA claims 70 in their instructions)
  • 1 month later...
can some one tell me the torque specs for steering linkage on a 2008 gmc sierra 4x4 z71 1500? Thanks. I looking for the part that attaches to the knuckle.
Application
Specification
Metric
English
Idler Arm Nut (at the Relay Rod)
62 N·m
46 lb ft
Idler Arm Nut (at the Vehicle Frame)
105 N·m
78 lb ft
Pitman Arm Nut (at the Relay Rod)
62 N·m
46 lb ft
Pitman Arm Nut (at the Steering Gear)
250 N·m
184 lb ft
Steering Linkage Shock Absorber Nut
40 N·m
30 lb ft
Steering Linkage Inner Tie Rod
100 N·m
74 lb ft
Steering Linkage Outer Tie Rod Nut
60 N·m
44 lb ft
    LeeBob
    LeeBob
  • Who's Online   3 Members, 0 Anonymous, 978 Guests (See full list)
