New Ipod Yesterday
I bought an ipod for the first time yesterday. Moving into the 21st century. At 53, I'm getting like an old person and not all that savy about electronics. I try, but it's hard for my generation to keep up.
I loaded up a bunch of my Marty Robbins and other trail songs along with some Hootie, Clapton, and some others. I'm going to just plug the Nano into the 1/8" jack in the front of my 08's factory XM radio's panel.
Question: Will using an interface box that feeds the ipod in thru the back connectors be significantly better sound quality? (I have the Bose satellite radio, no Nav)
Crutchfield recommends the Periferal Media Gateway or USA Spec GM ipod interface.
I have the aftermarket interface in my '07 with XM radio. I would think, that as long as the signal is wired into the radio you'd see no difference in sound quality. A wire's a wire whether it's in the back through a fancy interface or in the front through a jack. The difference would be that the peripheral interface gives you some ability to surf the ipod using steering wheel and radio button controls, while the jack just lets you run the tunes off the ipod and use the ipod controls.
if my factory radio had an audio input like the new ones, i wouldn't have purchased a peripheral interface.
the sound quality will be the same.
its easier to navigate the ipod using the ipod controls.
and its no harder to reach down and hit "next" on the ipod than it is to use the radio buttons.
save your money.
The sound will be better with the Ipod connected to the back of the stereo. If you go thorough the jack on the front you are using an amplified output from the ipod and the output from the dock connector is a line out...........
GM finally released the pal, so that is an option for connecting the Ipod.
In my mind the huge advantage to connecting to the xm input of the radio is that it will charge the Ipod while you listen. If you go aux in your ipod will run down on battery power.
they make car chargers for the ipod.
I am a 61 yr old and have a Zune (Microsoft version of Ipod) I made sure I had the Aux Input so I could use it.
But since the Radio/CD handles MP3 and WMA files. So I used the files for Zune that I have as back up and burned the files to a CD. I got about 220 songs on each CD. I put about 1300 songs on 5 CDs. They sound MUCH BETTER being palyed on the CD player. They have all the data. You can play random, album, or artist. Plus the titles read out on the Radio screen and are easier to read.(for old farts with bad eyesight for reading)
no sh!t?
I wasnt aware of that :lol:
I'm almost sure the front 1/8" jack is analog. Not sure about the interface boxes whether the input signal is digital or analog. I'll give this setup some time and decide if I want to have the controls thru the radio. The problem with that is that I don't have a large screen Nav radio and this radio has only one line of text capable, maybe two. I think controlling the ipod may be a PITA that way.
For charging, I found a host of cigarette adapters that convert to USB (5.5v) and I can simply plug in my USB ipod cable. BestBuy gets $26 for them and they're $5 on ebay.
no sh!t?
I wasnt aware of that :thumbs:
Your "huge advantage" isn't worth the cost.
no sh!t?
I have to concur that there IS a sound quality difference, and that for me, the lack of TWO wires running in the cab is really the biggest advantage I see. If I ran the audio jack I had to have one to the AUX and power to the ipod, which looked like a real mess, plus they came out both ends of the ipod. Now I have my ipod in the glove box where no one can see it.
I WILL say that the PXAMG controls for the non-nav stereo can be a little confusing and perhaps a little frustrating even, (but I can also say the same for the factory ipod connection on my BMW, so I can't fault them on that) If it bothered me that much I have 11 feet of cable so I can either pull it out of the glove box or I could run the wires to the center console if I really wanted to get fancy. I got the whole thing for about $120 on ebay and I find it was worth it to me.
-Jer
I'm new to this ipod stuff. But, for now, I'm happy with the quality of the audio thru the 1/8" jack. Pretty darn good, IMO. I think the compression factor of the ipod would have to be decreased to allow a higher bit rate before the 1/8" jack would be the limiting factor. I'm currently using itunes default compression which I'm told is about 120 bit.
I can see the issue with all the cables dangling around and I'm trying to come up with a solution for my current setup. I've mounted the ipod next to my GPS by velcro-ing a small alum plate to the back of the GPS and then the ipod to the plate. This makes it easy to detach the GPS/ipod assembly and tuck it into the glove box when I park. But the setup requires 3 cables if constant charging is desired. 2 charging cables for the ipod and GPS and 1 for the audio. I'm planning to combine the charging into one cable from the assembly to the cigarette lighter jack.
I did the above for a cost of maybe $2.50--the cost of 5 CD-Rs. Put 1300 songs on them.
The sound quality beats anything you can do using an Ipod (or a Zune) Plus it's easier to Read any Information about the file/song.
I know the point is to get away from CD's, but it's so much cheaper, easier to set-up and work with, and it's not that many CDs you have to work with.
Truthfully, I would prefer a USB connection for a USB Flash drive. But it's not on this Radio.
PLUS no charging worries or hassles, no cables to deal with, no cradles or mounting hassles either. Just store 4 CD's in console and leave one in the CD player. IT's great, and again---IT SOUNDS BETTER THAN ANY OTHER CONNECTION FOR THE IPOD ITSELF.
Bill I appreciate the elegance of the solution you're using. Sounds really attractive for most applications. During the hunting seasons, I spend some time off-road or on rough dirt roads and the CD's skip and jump around on rough roads. That's one reason I didn't get a ipod with a micro - drive in it. I'm sticking with a solid state solution.
  • 3 weeks later...
Nobody in this thread mentioned a buzz or whine from the speakers while playing the ipod.....I get it and find it annoying. I'm playing through the accessory jack in front, but I get the identical noise in my Toyota Solara playing through an FM transmitter. The noise changes in pitch and volume with engine speed, being quiet enough at cruise that I'll live with it rather than spend money chasing a solution.
Anyone else hear this?
BTW Chuck, you should have too many songs at 53 to fit on a Nano....
Yeah, I hear it when I have the Ipod plugged into the cigarette charger. Unplug it and it should go away. It's a bit of interference from the alternator coming thru the power circuit.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
