Gas Brand
Anyone here picky about what brand of gas you put in your engine? I have always used Costco b/c it's cheaper than anybody else but I'm not sure where they get their gas from. I have heard that Shell is a good brand of gas to use b/c of their additive pack. There are not that many around where I live so convenient is a factor. In the past I have always use the cheapest gas available but now I'm wondering if certain brand will make the truck runs better.
Shell 91, or walk.
Drew,
You seriously run 91? Is your truck running any better than 87? When I had my LS400, if I put anything other than premium it ran like crap. However, for the trucks 87 is often recommended.
Now that I've got a tune, I can only use Chevron and I've been using 89. I've tried 91 octane from 76 and I was getting some pinging.
Shell has a problem with their additives, they are detergents. Now I'm not a scientist, but from my knowledge, detergents clean, they don't burn well. I've talked with several people that work on tuning vehicles and I've heard the same story. Stay away from Shell.
Now on to a personal experience. I have my truck tuned with a Diablo Sport Predator. I was running my 87 octane tune at the time, pulling the trailer and I was forced to use Shell (no other option). My truck pinged HORRIBLY. Next gas station I stopped and topped up with high test and a couple of bottles of octane boost and it helped. I have also noticed that the pinging is worse with Shell (all grades) than any other REPUTATABLE brand of fuel. You can still get a bad batch of fuel that can cause issues, but that is the unknown.
Been running Texaco 87 in mine without any pinging. So does the higher octane stuff necessarily mean better performance and fuel mileage?
Tried the higher octane stuff in my Ford and it made absolutely no difference in either that I noticed.
All gas stations have the same gas. It has just been carried there in a different truck, and put in different tanks. Our gas comes from the gulf (at least it does in NC) and goes into a pipeline that runs from there to here. When Texaco puts in 1 million gallons of 87 octane in texas, they imediatly get the next round of 87 octane coming down the pipe here in NC, even if Shell or who ever put that gas in there. All grades of gas and diesel are run through the same pipes, believe it or not, and are run one behind the other. They used to run seperaters in between the different fuels, called pigs, but they don't anymore. The Fuel that becomes mixed together in the pipe is sent to powerplants and other places that can burn any type of fuel.
Any additives in the gas are added after the gas is in the truck. I honestly believe (and I'm not an expert on this) that you should get gas at the busiest and newest station in town, because they will have the newest tanks and the tanks are filled more often. Instead of the country store (which I like going to to get a ham biscuit) where only 20 people come to fill up everyday, and the EPA keeps investigating because of the old leaking tanks. Gas loses it's octane rating fairly quickly, and when it sits in a tank for a long time, that 93 octane may not really be 93 octane anymore.
The additives they use tend to have the reputation that they cause interesting "issues" relative to other brands. I find that interesting because many of their other motor oil/petroleum/chemical products are beyond reproach (Rotella, etc).
Back in my college days, I owned a VW Rabbit (Fuel Injected) --- give me a break, it was all that I could afford :rollin: . I still have the letter sent out by VW of America (back then, 1983 I think it was), indicating that any warranty concerns ref the fuel injection system (Bosch K-Jetronic back then) would be voided if it was determined that the customer was running Shell Gasolines --- yes, it's EASY to determine due to federally mandated chemical markers that are unique to each brand of gas. This was 25+ years ago, granted. Lots can change. I tried Shell SU2000 ONCE back then (prior to getting that letter), and the noises coming out of that engine were almost unbelievable. Switched to Mobil, all went away.
Now, for a major car company to call out another major company like that --- you KNOW that VW passed that thru their legal department once or twice. That implies to me that, back then, they had rock solid data/proof of the issue. Shell would NOT have let that go if they thought they could successfully dispute it. I remember it even making the major news outlets back then.
That has stuck with me ever since. I run Exxon/Mobil 93 virtually exclusively. I have a tune that requires that, as my timing is pushed to the limit for 93. If Exxon/Mobil is not available, I'll use Sunoco, Chevron and BP in that order. I consider them all top notch. Shell, I stay away from.
Where I live, we don't see Texaco. But I hear they make an excellent blend as well.
EDIT: BTW, Sunoco around here has quietly begun discontinuing 94 grade. Anyone else notice this where you are, or is it just the stations around here?
...you should get gas at the busiest and newest station in town, because they will have the newest tanks and the tanks are filled more often.
^^^ i clicked this thread to post these same thoughts. the real degredation of gasoline comes from condensation buildup in tanks at stations that don't do much business and thus have their tanks refilled less often. go to the station in your area that is the busiest, which usually ends up being the cheapest as well.
I have often wondered about gas differences. I assume nearly all of the gas in WV comes from Ashland, KY (major refinery or whatever is there). Nearly every station has the same truck deliver gas to the stations. Seems like a lot of trouble to put the Shell additives or Chevron additives in each truck before it heads to the station. And I have seen these trucks stop at multiple stations on the same load, I know they have different sections in the truck but it all seems like a lot of work to me. Back in the 90's my family had a gas station in a small town, privately owned, no brand of gasoline. About 3 miles up the road was an Exxon, they recieved the same gas from the same truck that my family's gas station did, absolutely no difference and who knows, that truck could have stopped at some other brand station before it got to ours???
This also brings up another thought, not long ago I noticed a new sticker on the pump at one of the stations that said "10% ethanol added", from that time on every different station I went to had that sticker, like they all put that on at the same time, which makes me wonder even more if its not all the same gas... And I cannot find pure gas around here anymore, I would love to find a list of stations that do not add ethanol...
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
