Disasssembling Tire Winch?
Long story short... My spare tire winch crapped out. I successfully removed it from the truck, but can't get it off of my spare tire. The winch has extended about 1.5", so there isn't enough room to turn the piece that holds the tire and slip it through the wheel. I used a bolt cutter to cut the cable that was extending beneath that (Between the metal piece that holds the wheel and the coil spring), but that did nothing to help. Any suggestions, short of spending some quality time with a hacksaw?
Thanks
Guess I was lucky when mine broke and I left my tire in the road for my buddy to pick up for me.
If you have to cut it, maybe a metal cutting blade in a sawzall would be more pleasant than the hacksaw. Good luck.
I'm not near my truck so can't confirm, but isn't there something in the owner's manual about this? Jacking up the tire and getting some slack....can't remember exactly.
Thew problem is there wasn't hardly any slack. It's done now though. I cut through about half of it with the hack saw, then bent the other half back and forth until it broke. I was then able to cut the cable, and it's free.
And when I first found out mine was bad, it was in the middle of nowhere, on a muddy dirt road. I jacked up the truck, took off the flat tire, then went to lower the spare, only to find out it was stuck. After about half an hour of wrestling with it in the mud, I hiked to the nearest house and called AAA. It took them 2.5 hours to get a truck out there. They couldn't get the spare off either, so I had to put the flat back on, and have the truck towed about an hour to the nearest Costco. Once I got there, I found out that the tire wasn't patchable, and every Costco in the state was out of that size. So I had to wait a few days without my truck, all because of the stupid tire winch.
So now, the spare tire is in the bed.
The manual does have a proceedure for fixing this which has been discussed multiple times.
The manual has a section on how to disassemble a winch which is stuck and won't go up or down at all because there's gravel in it? I must have missed that section.
. I had the same prob with mine and wd 40 the crap out of it and ran it up and down and it eventually came down. now i just run her half way down twice a year and soak her with graphite and run her back up.
If you're going to fill your tire hoist with gravel, I think it's now up to you.
Okay, that last response actually had me laughing out loud.
You know it’s funny, I posted about a year ago how I lowered my spare and sprayed the cable and winch with Zep 45 and a couple of guys posted, “what that’s what you do in your spare time?” I know it doesn’t do anything for you now, but I posted it to get guys thinking of doing that so when the time comes, what happened to you doesn’t happen.
Too bad it fills itself up on gravel roads.
I would definately go with the spare in the bed. If you think it wasn't fun this time, wait for -20 laying in the snow trying to chip the ice off underneath so you can get your spare down.
Heh, ironic this post is here today.
I had a flat on my way out of town today. In addition to the stupid "secondary latch" not disengaging (it took three guys to get the god damn spare down), the POS jack wouldn't go high enough to get the spare tire onto the hub. Who designed these frigging things!?
Good thing CAA was about 15 minutes away with an air bag lifter. I GOTTA get me one of those.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
