Resetting The Tire Psi Display
OK, I am not sure of the technical name for the thing that gives you your tire readings, but mine is off calibration. I had it in to the dealer earlier this week to take care of a bad tire issue. They rotated the tires, and ultimately ended up replacing a tire (under warranty). The tire that was bad was the LF. Now the LF shows @ 34 psi, while the rest show about 30-31. I manually checked the tires myself, and they all show 30 psi. I am on vacation now, and could take is to a local dealer, but don't want to spend the time waiting, I want to enjoy my vacation. Not a huge deal, but it would be nice if it was working. Is there is a way I can reset it myself? Thanks.
Don't think you can "reset" these, but you might try the Re-learn procedure outlined in the owners manual.
Maybe they damaged that TPMS sensor in the rim when they swapped out the tire, although a few psi difference isn't really that big of a deal and might be consider normal...
I would venture to say that the TPM (tire pressure monitor) in the tire is bad, and there is no calibration. You would just need a new one (TPM is actually part of the valve stem but on the inside of the wheel).
The TPM system is only intended to warn of low air pressure in the vehicles tires. You were correct in checking all tires with a known good gauge and to not rely on the TPM system. All systems are off by some amount don't worry about it and enjoy your trip.
The DIC shows about 2 psi lower than the actual sensors read, not sure why. I have the OTC 3833 TPMS tool which shows what the sensor is broadcasting.
2 psi differental is normal even my 08 CTS4 & Vett will show 2-4 psi difference.
That's good to know. It bugs me to see 35, 35, 36, and 35. I like things like that to be tidy.
It's normal to show 35 at the sensor with the tool and 33 on the DIC? That sounds wrong to me unless they do it on purpose so people will fill their tires a little earlier than needed if they only go by the light.
You cannot possibly get two or more gages analog or digital agree 100% due to variance in calibration, temp, humidity or barometric pressure all vary at any given time. Any gauge reading is just a number, your blood pressure too can very on more than one reader.
Maybe I'm not explaining correctly, it's the same device reading the pressure. I use my tool to pull the pressure reading from the sensor in the tire, then I look at the DIC (which reads from the same sensor) I get a different pressure. There is 1 piece of equipment that both items are getting their information from. They should be the same.
I know what you mean and I wish mine is exact as well. I have one tire
that is constantly off by 2 or more PSI. Dealer did the reprogram re-learn
thing but no luck. I just live with it.
32, 33, 34, 34 in the mornings
34, 36, 36, 37 in the afternoon during rush hour traffic
Before I had the tire trouble, they were all in a pound of each other. But, I hadn't actually checked it with a gauge at that point. Still puzzles me. I will take it back to the dealer after I get back from vacation. I have a couple of other minor issues for them to look at.
I've never had any trouble with mine. A few times a year I check the DIC against my tire guage and they always match perfectly.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
