Total Chaos Uca Kit?
Does anyone know anything about the total chaos UCA kit? It says when ran with coil over shocks it add another 2" of like while most coil-overs add 2" the mathematician within me thinks thats about 4" of lift. What do yall know about this lift set up? Wouldn't you need some rear blocks? Is it structurally sound? Would it save money on labor hours since its just shocks and upper control arms? any feed back is appreciated. http://www.chaosfab.com/77500.html
What those do is allow for more travel so you can add lift with coilovers, or a leveling kit, etc. Normally adding a leveling kit will decrease the ride quality because of less "droop" travel. These UCAs will correct that. They dont add lift just allow for more lift. They would work with a suspension lift too. If you already had a 6-8" suspension lift and wanted to go bigger, and still keep stock travel, u get these...
Atleast thats how I think it works!! Ive never ran them.
Oh so they pretty much allow you to run a leveling kit or coil-overs on top of a suspension lift
That's not what they are intended for, but they would help correct the ball joint issues in that case.
