My truck already was in the shop 3 1/2 years ago for the recall and within the last year I've replaced the wheel bearings anyways, which came with new sensors. I don't believe the dealer will do the recall a 2nd time for free
I was informed on my 04 that it's not a recall, just that there's a TSB issued for it.
I just did the repair that GM says to do, and found it to be quite easy. The sensors are a pain to pull completely out, they come about half way and then got stuck and I had to gently use a pair of pliers to get a firm grip and get them the rest of the way out. I can see where some people have had them break off.
Then it was just a good sanding job and some grease and put it back together.
For what was supposed to be a quick repair, it was. And other than the fact once I had the rotors off I discovered I needed new rotors, it was free to fix.
Took my under an hour to do the actual sensor fix...the hardest part was loosening the bolts on my brakes, they were pretty tight. After doing the fix, I havent encountered the issue that I was, so I recommend attempting the fix yourself if you're even remotely mechanically inclined, as I found it very simple and self explanatory.
One wheel bearing & sensor is brand new and the other side I already cleaned up with the same issue. Something else is going on but I haven't had a chance to schedule an appointment to get it in to the dealership.
My truck just started doing the same damn thing. Low speed, coming to a stop, and the whole truck vibrates when the antilocks kick in. Our of warranty too. Nice.
Found out it is the passenger side sensor not reading the correct speed. It is an aftermarket wheel bearing that is about a year and a half old. I took the stock sensor out of the old driver side bearing and put it in the passenger side and it still acts up. I had the dealership tell me what was wrong, but I wasn't gonna shell out the money for them to put a gm bearing & sensor in it. I'm afraid to spend another $115 on an aftermarket and not fix the problem.
Are you more scared of paying out what GM wants to fix it...or rear ending someone and having to pay out the cash for an insurance claim?
Bet GM isn't charging you anywhere near what your insurance will charge you, for both your deductible and your increased rates for the next few years.
I read somewhere that people have pulled the fuse out as a temporarily fix. But i am not sure if that would work in your case. You would not have the abs of course, but would be safer than the alternative.
I have the fuse pulled for now so that i don't have any accidents, I had to many close calls and pulled the fuse as it is safer than the abs kicking in every stop
Got the truck fixed. Took it to dealer finally and they told me it was actually the passenger side that was not reading to correct speed. I put a new bearing in this afternoon and after a 5 mile trip around the block, I never had any problems. I had put a different known good sensor in it over the weekend and that hadn't fixed it, so the bearing was next. That bearing was only about a year and a half old, but the tone ring inside must have been messed up in some form, but nothing I could see. Oh well, ABS works now and I don't have to stare at the lights on the dash.
I'm having the same issues. Anyone have pictures of what I should be looking for? Or a link to the TSB?
Mine's an '05, but I don't think that it matters....
A shop will be able to read the wheels, and see which VSS is not lining up with the others. I just had this on my moms saturn vue red line. For the saturn, I had to replace the whole hub, as it is part of the assembly.
I have the same problem on my '06.....I asked if GM was going to expand the recall being that a number of newer vehicles are experiencing the same issue as the older recalled vehicles...I was told "No"...so I reported the problem here ( NHTSB )...maybe if enough complaints are lodged, they'll expand it. Feel free to join me.
it is not a recall just a TSB and most dealers will not perform this for no charge because they don't want to get stuck with the bill if you are out of your 3/36k warranty.
I had the same issue with the cloth interior TSB on my 07 GMT900 which I purchased with a GM Certified Warranty. The dealer would not perform the TSB so I called the GM warranty customer service # and told them what was going on. They contacted the dealer and within 24 hours they called me back and said the dealer would take care of it.
I hate to bring up an old thread but this may be the answer to my problem. When applying the brake a a low speed and hitting a bump the abs would kick on and it was like I lost brakes completely. Did it once or twice last fall but then did it in the a few days after christmas when out plowing and ended up rear ended a car. Plow prevented any damage to my rig but messed up her bumper and now my insurance just went up abit :crazy:
Anyway now that the weather is getting better I definatly would like to get this fixed. What exactly to I have to sand/clean up? I keep hearing about a possible recall for this but can't find any good info. Truck is a 2000 3/4 ton Silverado and I'm in Vermont so I'd assume that would be in the "salt area" that I heard mentioned
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
