Dex-cool Or Red Antifreeze
I had a roofer over looking at some hail damage on my roof and he commented in my 08 silverado. He had a 09. He had 115k on his 05 and said his dex-cool jelled up in the heads and fried his motor. He drained it out of his 09 and put in the green. Has anyone ever heard of this before?
Have heard stories on older vehicles. Main thing is to NEVER mix any other coolant with Dex. If you ever develop a leak, fix it. Running with low coolant allows air into the system and that's not a good thing for Dex.
Dex is good stuff. Don't believe the 150k thing or whatever it is. Change it before it wears out and you'll be fine. I've got an '04 with Dex, changed it a while back. No jelling. Flushed it thoroughly. Installed fresh Dex.
Your roofer probably didn't maintain his truck very well.
+1
I agree, there is nothing wrong with DexCool .... the worst thing you can do to DexCool is mix it with other coolant (like the green stuff... Prestone or whatever...)
.. and then, like all antifreeze coolant, you need to change out and thoroughly flush before the DexCool drops in pH and becomes acidic
Mixing DexCool with regular antifreeze will cause it to gel up just like he said. Also the color doesnt matter. I know DexCool comes in a few colors.
What have you been using to test the ph?
What are the "good" numbers to see to be in the safe zone?
I asked my mechanic that and he said they just use some pH paper strips (... is it called litmus paper???) and compare it to a color chart after dipping in the coolant ... apparently the color chart just says good, marginal, or change.... they check at every oil change
I have read in other places that ideal pH is about 9.5 to 10.5; recommend change/flush at 9.0; consider unacceptable at 8.3 ....
... others may have some other references with slightly different numbers
... I have never actually taken a pH meter and tested mine myself
... watch out for 'quicklube' places that tell you it's time to flush.... first they may just be trying to upsell you something you don't need; and then second, they quite likely won't have the equipment or take the time to actually pressure flush your entire system out adequately.... drain and fill is not enough the flush your system out.
yup...10.2 is ideal...and should be kept at or around this at all times.
You can test using pH strips, or old fashioned pH testing kit with litmus paper (white stuff, not the pink and blue you used in high school chem class) and a card to show you the colors of different pH levels. They're dirt cheap, and come with enough strips to test the system once a week for a year. They will get you in a .5 pH range ...so you will be reading 10-10.5
I change it when the pH drops below 9.5 or the freezing point drops below -30*C, or a little bit of sludge starts to form.
Have a question for you guys...what year did GM start using the Dex-Cool? Is it better at cooling than the green stuff?
Dex-cool cools better than regular from what I've read. Mixing it has been the issue but as more and more vehicles have it factory installed, it's not as much of a problem anymore. People were just ignorant and mixed the two types causing all the issues.
Dex-Cool is less toxic. I had a dog get into some once, just gave him a tummy ache.
Your roofer needs to stick to roofing till he learns more in the automotive field.
I have used Dex-Cool since 1995 with out issues, and one of the vehicles had over 250,000 miles.
    Mistycool
    Mistycool
  • Who's Online   4 Members, 0 Anonymous, 1,768 Guests (See full list)
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
