Tekonsha P3 Brake Controller Instal
I have searched this site for installation instructions for the Tekonsha P3 brake controller but the links are old and not available. Does anyone have a good link or have detailed instructions for installation? The instructions this thing comes with are just not doing it for me. Thanks!
Great, That helps!!! So the brake controler in your link is the Prodigy. Is the Prodigy the same as the P3 as far as wiring goes? Thanks, Bill
well, it was similar but i do not believe it was the same. that guide deciphers which wires in the GMC harness are which...and the P3 instructions should tell which wires correspond. it was a very simple install. the hardest part was finding the correct sized nut to for the power taps under the hood. i just wire-nutted everything together under the dash, electrical taped it, and wire-tied it up there. mounted mine on the extreme right side because there was more flat plastic available to mount it.
The new P3 works great, thanks again for posting the instructions!
