Switch,stop Lamp Part Number
ryan_hermanutz
I need some part help. As we all know our brake/stop light switch in the GMT900's suck, release a little bit of pressure and it goes off. Well after getting rear ended I think it's time get it fixed. Can one of you guys verify that this part number is the correct one 25991704. Thanks in advance!
Sweet, what dealer should I call then; I've called 3 different ones and got 2 different numbers. Are there any technicians that can answer this, so that this fits in the “ask a tech”, which number is correct 15881245 or 25991704?
There is a topic just on this. I will look for it for you. I got my number from there and it worked great.
Thanks buddy and that is why there is a question, the part number I got off of that posting http://www.gm-trucks.com/forums/index.php?...2994&st=225 is an year old and 2 of the dealerships said that it was an old number no longer valid and the other said that it was an old one but they thought they could still get it.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
