2009 Sierra Problem (grey Milky Fluid In Front Differential)
Hey guys i just wanted to inform you on a problem i just encountered on my 2009 Sierra 5.3 Litre. I bought it brand new. I live in Canada in a cold Province where it has been around the 30 below celsius lately. My truck has 8200 kilometers on it, which converts to 5100 miles. I went to do my oil change, i do my own. I have worked on vehicles my whole life. My dad is a heavy duty mechanic and has been for 45 yrs. I grew up helping him in our family garage. Anyway, i changed oil in it yesterday and i thought i would check my front differential fluid. To my disgust, i take the plug out and check it and it is milky and looks like it has water in it. I was like, "what the f%&k?". The truck has never barely seen rain let alone driving through water. The dealer was closed when this happened so i took it there this morning. They checked it out and sure enough there was milky shit in there. So, they took it into service and checked everything out. They came back and told me they found no problems. The mechanic said it was not water or condensation. He said it looked like Grey paint. He said he has seen this a couple of times in his career. I am not sure what to believe. Has anyone else came across this? They flushed it out and changed the fluid. $110 later of course. They told me to drive it for a week then bring it back, if it is milky again they will do more looking and not charge me for it. I dont think i should of had to pay. I never put grey paint in there. What do you guys think.
I know i rambled on at the beginning, but i wanted to tell you all the facts.
I don't know what to tell you about the "grey" fluid other than i have seen diff. that have seal leaks and turn a milky color. But i think its B.S. that your dealer charged you to flush it knowing that it only had 5200 miles on it and you sure the heck wouldnt put paint in your own truck. I would suggest that if you have to take it in again for the same problem to request a refund of your $110.00
I use to four wheel too many times to count in my younger days and got water everywhere. That is water in your diff. if it looks milky grey. As soon as water mixes with gear oil it will make that murky grey mess. I always pulled my cover off and sprayed everything down with brake-cleaner and than re-fill. There should be a vent somewhere at the top for a breather, If the dealer checked it out than hopefully should be OK.
Seriously doubt there is that much condensation, but it does sound like water in the lube. Should have been a warranty issue. Something had to leak.
It's too bad you did not take a sample of the oil for testing. It probably is a cheap test in a lab to see if there is water in the oil or not.
+1
The only way to know for sure what the contamination is would be an analysis. Technicians all have opinions but some are based on facts and some are based on BS.
When I changed my factory oil at 3K miles it was the same way. I've had water mix with the gear oil in my TJ's axles before and that is what the oil looked like except it was more of a gray color vs milky white. I drained it and refilled with Mobil 1 75W-90 Synthetic and have not checked it since. I have no problems and the 4X4 works fine. I might pull the plug and drain a little bit and see if this M1 oil did the same thing.
don't remember the exact color of the diff fluid when I changed mine out at 25k miles but do recall it was odd looking--I'd heard the GM Grape Juice they use doesn't look like anything else...refilled both ends with Mobil1
Hey guys,
Yeah i would describe the oil to be more of a grey than a milky colour. It was alarming nonetheless. Thats all i need is to have knocked out the differential b/c of something so dumb. Especially when i was not my fault it the least. It would have been different if i left it in there for 100000 miles and never touched it but at 5100 come on. Thats brutal. I hope the problem is solved but knowing my luck it wont be. I have terrible luck. I will keep you posted when i take it back there for the test again.
Drained mine after 4x4n some water holes this summer.. no water in mine at all.. ust dark.
Your saying its really cold outside, this vent there talking about get ice in/on it? And every time you pull in to your garage from when its cold outside I can see it condensing down. short trips + frequent garaging.. But either way im with these guys thats bull and the dealer should of covered it under the power train warranty.
It sure sounds like water. Anyone know if there are any additives that the factory might be using? Molybdenum?
Update After 600 Miles:
Hey guys thanks for all your responses. I appreciate everyones help and opinions.
I drove the truck for 600 miles then took it back to the dealer to have the differential fluid checked. They took a sample of it out and it looked alot better. I thought it still looked a little funny but i have no experience to know what good compared to bad is. The service manager looked at it with me standing there and he said it was fine. I said as long as it is documented that you think so and give me the okay to continue to drive it i am happy.
Then i was aggressive with him and told him that i want a refund for the 109 dollars it cost me the 1st time i was there to get it changed. He was not there the 1st time i had it changed. So, after a little calm debating he told that he would do some investigating and see what he could do. So, i left doubting that i would i would get mony back. To my surprise i wasnt home for an hr and i got a call from him and he explained that it was a gm problem and not mine and i would be getting a cheque in the mail for my 109 within a week.
I am happy with this. I guess my dealership came through. I just hope thats the end of the problems for awhile lol.
Again, thanks guys
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
