2007 Tahoe Problem
ArmyAviator
Wife's 2007 TAHOE; not 4x4; never towed; synthetics from nose to tail. Rear differential has OEM fluids; not changed to date.
"Growl" began 2 weeks ago @ right rear wheel area. Inspected to check for foreign body in brakes or whatever; found nothing. "Growl" can be heard by hand turning hub. Rear differential plug shows "shavings/particles."
Two questions please:
1. I've checked for recalls/campaigns on online; found none. Yup, the vehicle is @ 50K+, so out of warranty.
2. "At the feed store", a fella told me that he thought the bearing was a sealed deal in the hub; that I'd hafta replace the whole rear wheel hub. Fact? Is this a major $$$ item? The axle is solid; not independent suspension.
All the best, from Alabama.
--Bryant
The axle lubricate the bearings by diff lube being pushed out to the wheel bearings. If it's the wheel bearing, it's just a matter of pulling the axle and replacing the bearing.
Have you checked the other side? Do you any abnormal noise at the diff itself? I'd pull the cover for a thorough inspection.
ya you have no hub ,ive never replaced one of those bearings ,
don't throw parts at it ,it will pay for a real diag
Thanks for the fast replies, Fellas.
I'll check with my local dealer to see if any open recalls/campaigns might be out there.
I'll pull the diff cover, check both sides, and then fix what's not right.
Robert (gmtech4), thanks for the info that I don't have a hub; that's it is a bearing there. I agree not to just fling new parts without having it all checked out first.
--Bryant
