I know it's a ford pulling the boat guys but I didn't have a picture of my truck pulling the 2 rhino, 18' trailer, and my sportman touring in the back of the truck. I'll have to post it later.
This is what I pull daily at work.
Geez Jamie, what is the tongue weight on that thing? The front tires look to be floating!
Boat and trailer is about 9000 lbs. It's a 26' SeaArk with a 350 in it. We car an extra 30 hp motor on the back. It has an on board 7.3K generator. It really squats the poor little F350. I'm guesing there is about 3000 lbs tongue weight.
Not my truck but GM truck none the less...... Too bad Toyota fans.... Yes, that would be a CHEVY pulling the TOYOTA racing trailer!!!!
I saw these pictures a year ago or so. Googled and found them again...
Jbo
Jbo
Ha! That's funny. :lol:
the F-350 in my post above has the V-10 6.8L in it. It's a real turd on hills and it averages about 6-6.8mpg pulling the boat. We have about 25000 miles on the truck and 23,000 of them are towing that load.
Jbo
That is hilarious, any Toyota forums that these pics should be posted in? :lol:
the ford v10 is an awful engine.. no more power then a v8 and god awful gas mileage and from my expirences bad reliability...
that looks like a 1500. and what kind of car do you tow in that trailer? i have to go pick up a buddy's 69 camaro with an enclosed trailer in the next month or so and was curious to know how that handles?
here is a pic of my old 03 (4.8 and 3.42 gears) pulling my freshly powder coated frame home from the shop.
The 03 wasn't enough to pull the Monte Carlo once I got her back together so I picked up my 09 with a 5.3 and 3.72 gears
I would love to have my own trailer, but I just don't have the space for one
Edited by DoMDrty
Post lift towing pics. not much sag if any at all. the first pic is on a hill so it looks tiltled.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
